MF-12 intermittent non-running ignition/electrical problem
10 replies to this topic
#1 SuperMowtard OFFLINE
SuperMowtard
  • 7 Thanks
  • 6 posts
Posted November 10, 2016 - 02:44 PM
Hello all!
Perhaps is should describe my problem as an intermittent RUNNING problem as it spends more time in the non-running state than running.
I recently picked up this MF-12 and it doesn't like to run for any usable amount of time.  Most of the time it will start right up but die shortly after.  It dies quickly.  No sputtering or stumbling beforehand--just quits as if I turned off the key.  After dinking with it for some time, I noticed that it would run up until I let the key off the "start" position and into the "run" position.  So as long as I hold the key in "start" it seems to run OK.  I imagine keeping the key in the "start" position is probably not a wise long-term solution!!
Very rarely, it will continue to run in the "run" position, but only for a handful of seconds.
Can anyone offer any guidance?  Is there any reason to consider possible causes other than the key switch itself?
I downloaded the MF-10/12 electrical schematic from the forum library, but it leaves a lot to be desired.  I'm hoping that the manual which that schematic was taken from has some more in-depth information, but I downloaded all the manuals that I thought would pertain to my 12 and haven't found that same schematic in any of them.  (Am I blind?)  Can anyone direct me to that manual?
Thanks to all.  Anxiously awaiting your wisdom!
  • DMAX said thank you
#2 SuperMowtard OFFLINE
SuperMowtard
  • 7 Thanks
  • 6 posts
Posted November 10, 2016 - 03:59 PM
Ok, so I may have answered my own question.  Let me know if my reasoning is flawed...
I dug out my old test light and probed around the key switch.
I got no voltage at the "D" terminal of the switch (PINK wire) in the "RUN" position, but the test light did come on when I turned the key to "START" and cranked the engine.  I assume the PINK wire is what powers the ignition system and it should be live in both the "RUN" and "START" positions, but it appears to be dead in "RUN".
Based on this, I think the problem is a bad switch.
I'm curious to know what the letter labels for the switch terminals in the diagram mean.  I think I can guess three of the four.  "B" would be "Battery" for power coming into the switch, "C" would be "Charging" since the wire from it goes to the regulator, and "S" would be "Starter" as it goes to the starter solenoid.  But what does "D" stand for???
#3 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted November 10, 2016 - 04:01 PM
The ignition switch is probably failing.I have taken them apart and tried to fix with mixed results. Probably not worth the frustration
It is VERY important you get the right one or you will be destroying hundreds of dollars in ignition components.
I would ask the site sponsors here to sell you the right product.
  • DMAX, boyscout862 and SuperMowtard have said thanks
#4 propane1 OFFLINE
propane1
  • 12744 Thanks
  • 5754 posts
Posted November 10, 2016 - 04:03 PM
I would start with the key switch. And check the wire going to the solid state ignition, that it is not grounding out on some metal, which will shut the spark off, same as if you shut the key off. Some thoughts I had. Good luck with it.
Noel
#5 SuperMowtard OFFLINE
SuperMowtard
  • 7 Thanks
  • 6 posts
Posted November 10, 2016 - 04:32 PM
Thanks for the input so far.
Can anyone tell me if the pink wire is supposed so supply power to the ignition system, or if its purpose is to ground out the ignition system to shut the engine off?
#6 boyscout862 OFFLINE
  • 14843 Thanks
  • 9893 posts
Posted November 10, 2016 - 05:03 PM
It dependends on which engine you have. If your engine has a magneto the switch grounds out the wire to the magneto, to kill the engine. Never put power to the magneto wire. It will cost alot. The correct switch for a magneto system will have a tab labelled "M".
A coil based ignition system needs power to work. The switch will have a tab labelled "I". Most schematics will show the labelling of the switch tabs.
I think that your switch is worn out or you have a short in the magneto wire. Mice are great at causeing problems like that. Good Luck, Rick
Edited by boyscout862, November 10, 2016 - 05:04 PM.
  • propane1 said thank you
#7 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted November 10, 2016 - 05:11 PM
The Massey 10 or 12 with tecumseh is always ground out. They never made one with power to coil until they made the 14's and 16's, (Kohler) then the 4 digit units. ( var mfg)
#8 HANKG OFFLINE
HANKG
  • 6961 Thanks
  • 3671 posts
Posted November 10, 2016 - 06:00 PM
Don't mess with an ignition switch if gets stuck you could burn all the wires the voltage regulator and even the tractor. Buy a new one fast.
  • DMAX and boyscout862 have said thanks
#9 SuperMowtard OFFLINE
SuperMowtard
  • 7 Thanks
  • 6 posts
Posted November 13, 2016 - 01:43 PM
Thanks for all the replies.  Now that I know that the ignition system is grount-to-kill, it seems like the switch is probably behaving correctly, but I'm still a little stumped.
I'd like to turn the conversation towards the schematic I mentioned.  Here's a link to it.  (Probably should have included the link in my first post.)
http://gardentractor...wiring-diagram/
This wiring diagram is clearly just one page of a larger document.  Can anyone tell me what document this schematic came from?  Is it in the library?  I can't seem to find it.
#10 esbbent ONLINE
esbbent
  • 537 Thanks
  • 355 posts
Posted November 13, 2016 - 02:04 PM
The operators manual for the MF10-12 has a wiring diagram for the tractor.
  • MH81, propane1 and SuperMowtard have said thanks
#11 DH1 OFFLINE
DH1
    Electric Tractors
  • 5495 Thanks
  • 5633 posts
Posted November 13, 2016 - 06:13 PM
The link you post is the wiring diagram for the MF10, MF12 tractors, it is part of the manual that came with the tractors.
The pink wire that goes to the key switch is for killing the ignition, connects it to ground to stop the spark.
The ignition is self powered and should NEVER have battery voltage applied to it.
There are 2 wiring diagrams for the MF10, MF12 tractors, very early models had points, later ones have the SSI ignition.
http://gardentractor...iring-diagrams/
I would say your problem is the key switch or a wiring problem grounding out the ignition intermittently.
  • DMAX, MH81, KennyP and 1 other said thanks
