Ford Lgt 145 deck belt
9 replies to this topic
#1 sethra OFFLINE
sethra
  • 44 Thanks
  • 54 posts
Posted November 10, 2016 - 01:20 PM
Hey I'm new to the forum ! But I have a ford Lgt 145 close sided. And the deck belt keeps getting all chewed up when I mow. Iv replaced it 2 times already but it keeps happening. (Not the belt form deck to pto.) has anyone expierences this before ? What could be going wrong
#2 Bolens 1000 ONLINE
  • 14,989 Thanks
  • 18,141 posts
Posted November 10, 2016 - 01:25 PM
What kind of belt are you using?
OEM, aftermarket?  Auto store belt?
#3 sethra OFFLINE
sethra
  • 44 Thanks
  • 54 posts
Posted November 10, 2016 - 01:49 PM
im using a 1/2 x 96 in husky Kevlar v belt from Tractor supply.
#4 Bolens 1000 ONLINE
  • 14,989 Thanks
  • 18,141 posts
Posted November 10, 2016 - 02:01 PM
Make sure all pullies are aligned and no bearings are worn in the idlers. The only way you can break a kevlar belt is improper routing or worn / misaligned sheaves .
is it possible you have the wrong size belt?
#5 KennyP ONLINE
  • 38,513 Thanks
  • 45,987 posts
Posted November 10, 2016 - 02:17 PM
Which deck do you have? The 50 inch deck need a 97" belt according to New Holland Parts.
  • Bolens 1000 and boyscout862 have said thanks
#6 sethra OFFLINE
sethra
  • 44 Thanks
  • 54 posts
Posted November 10, 2016 - 09:10 PM
i took alook at it again today and found rust on the inside of two of the pullys.. i think thats why its wearing so bad..
#7 sethra OFFLINE
sethra
  • 44 Thanks
  • 54 posts
yes i have the 50in deck. i do have a 96in belt though. would one inch make that much of a difference ?
#8 KennyP ONLINE
  • 38,513 Thanks
  • 45,987 posts
Posted November 11, 2016 - 06:02 AM
Sounds like those rusty pulleys are the issue. You are probably okay with that length once the pulleys are cleaned up or replaced.
#9 sethra OFFLINE
sethra
  • 44 Thanks
  • 54 posts
Posted November 11, 2016 - 08:36 AM
Do you have any suggestions as to how to get the pulleys off ? I don't really want to use a gear puller because I don't want to reef on them too hard and bend them making them completely inoperable.
#10 KennyP ONLINE
  • 38,513 Thanks
  • 45,987 posts
Posted November 11, 2016 - 08:55 AM
I answered this in the other thread.
