Effects of a smaller port on flow rate
10 replies to this topic
#1 MacWorld OFFLINE
MacWorld
  • 4 Thanks
  • 58 posts
Posted November 09, 2016 - 03:25 PM
I am planning on adding hydraulic circuits to my 1977 Massey Ferguson 1655 by using 6/2 valves. Here is what I know (tell me if I am wrong somewhere)
The hydro-static unit is a Sauer Danfoss 15. From the specs, the ports for the implements are 9/16-18 (SAE #6 if I am correct) and the flow specs are
3.50 GPM @ 200psi - 3300rpm
0.25 GPM @ 800psi - 3300rpm
The valves I am looking at are Bosch Rexroth L710 family of 6/2 valves, with SAE #4 ports. They advertise max 4500psi 6.6GPM.
Would those valves have any impact on the implements? I am mainly wondering since the implement ports of my pump are SAE #6. I don't remember if the tractor's tubes/hoses are 3/8" or 1/4", there is a 90° between the pump's ports and the hoses, they MAY be reducing the size. Why are the ports SAE #6 when it seems SAE #4 would be overkill?
I plan on keeping the original tubes/hoses between the pump and the main valves of the tractor, then run 1/4" tubes/hoses to the L710 valves and continue with 1/4" tubes/hoses from the L710's to the implements.
Thank you!
#2 KennyP ONLINE
  • 36,513 Thanks
  • 44,965 posts
Posted November 09, 2016 - 06:07 PM
I'd like to know the answer to that myself!
  • Bmerf and chieffan have said thanks
#3 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted November 09, 2016 - 08:07 PM
X3
Maybe contact Bosch, see what they say.
Edited by stiemmy, November 09, 2016 - 08:09 PM.
#4 gopher OFFLINE
gopher
  • 749 Thanks
  • 752 posts
Posted November 09, 2016 - 08:48 PM
If your referring to dash numbers -6 would be 3/8 inch. Going to 1/4 would not have a lot of effect on cylinders. But if your talking trying to run something with a hydraulic motor your volume would drop almost half. Not sure if you can find something to run with 3.5 GPM. Not familiar with hydo-statics. So if I'm wrong some one more enlighten with these will chime in.
#5 ducky OFFLINE
  • 1,964 Thanks
  • 4,087 posts
Posted November 09, 2016 - 08:57 PM
You will be OK with a 6.5 GPM valve as the flow of the charge pump is around 4-5 GPM.
I am curious as to how you are going to plumb it into the system if you keep all the original piping intact?
#6 MacWorld OFFLINE
MacWorld
  • 4 Thanks
  • 58 posts
Posted November 09, 2016 - 09:10 PM
I will only be keeping the piping between the pump and the tractor's valves (the ones with levers that I operate). I will be customising the rest from those valves to the 6/2 and then to the implements.
If I understand correctly the original SAE #6 ports were way too big for the pump's needs?
#7 ducky OFFLINE
  • 1,964 Thanks
  • 4,087 posts
Posted November 09, 2016 - 09:17 PM
Is it an open center valve?  If not it will not let flow back to tank when not in use.
#8 Alc ONLINE
  • 6,609 Thanks
  • 7,338 posts
Posted November 10, 2016 - 06:39 AM
Maybe this will help with others with your question .
http://www.hydrover....lusso_VS120.pdf
  Ducky are you saying he should make sure the new control valve ( not the 6 port one ) will need to be " open center " ?
#9 MacWorld OFFLINE
MacWorld
  • 4 Thanks
  • 58 posts
Posted November 10, 2016 - 10:33 AM
Why would I need a open center? If I am using one implement I expect the other one to stand still.
i.e.: lets consider my 3points lift cylinder circuit: during winter the 3points will have my counterweight attached to it, once raised I will switch the L710 and I will be using the circuit for the snowblower chute orientation; I expect the counterweight to stay up!
#10 olcowhand ONLINE
  • 39,698 Thanks
  • 30,979 posts
Posted November 10, 2016 - 10:41 AM
It will, provided the cylinder piston seals are good.
#11 ducky OFFLINE
  • 1,964 Thanks
  • 4,087 posts
Posted November 19, 2016 - 08:01 PM
I misinterpreted the installation. I thought he was adding more spools.
I see now that he is just splitting one of the circuits.  That would not require an open center valve. It is just a diverter valve.
