1966 Montgomery Wards/Gilson 10 hp.
governor
4 replies to this topic
#1 thewarden6418 OFFLINE
thewarden6418
  • 1 posts
Posted November 08, 2016 - 07:23 PM
I suspect governor not operating correctly.. When I open throttle slightly,engine revs all way up ?
1966 Briggs 10 hp.  model#243434  type#0147 01   code#6612061
Maybe air vane under flywheel housing ?? Do you have to remove engine to get housing off?
#2 KC9KAS ONLINE
KC9KAS
  • 5,203 Thanks
  • 4,587 posts
Posted November 08, 2016 - 07:56 PM
:welcometogttalk:
If the flywheel end is attached to a drive shaft to power the machine, YES it has to come out!
#3 boyscout862 OFFLINE
  • 11,844 Thanks
  • 8,686 posts
Posted November 08, 2016 - 09:03 PM
Welcome to GTT. Check our Manuals Section for info that you need. Check the manual, you may be able to adjust the governor in the tractor. Good Luck, Rick
Edited by boyscout862, November 08, 2016 - 09:04 PM.
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,192 Thanks
  • 5,790 posts
Posted November 09, 2016 - 01:56 PM
:welcometogttalk:
#5 Sprint 6 OFFLINE
Sprint 6
  • 209 Thanks
  • 268 posts
Posted November 09, 2016 - 06:01 PM
Governor should be mechanical on the that engine, no air vane involved.  I would start by checking to make sure all the linkages and springs are intact and hooked up.  Then do the base adjustment as per the Briggs manual.
Also tagged with one or more of these keywords: governor
