Trouble starting My St16
3 replies to this topic
#1 schoust OFFLINE
schoust
  • 1 Thanks
  • 40 posts
Posted May 30, 2011 - 09:30 AM
Hi Guy's having starting issues with my St16 the tractor has a new solinoid a new starter and a new battery. The ground's are all good and the starter engaugment is also fine.? What else can be happening?? It seems I have to jump start it every time??
Any idea's??
#2 chopperfreak2k1 OFFLINE
chopperfreak2k1
  • 18 Thanks
  • 431 posts
Posted June 02, 2011 - 10:30 AM
it sounds like your tractor is not charging your battery. go through your charging system, maybe you need a new stator?
#3 MH81 OFFLINE
Posted June 02, 2011 - 07:42 PM
You could be dealing with corroded wires at the crimp connectors. Have had that a couple of times. To test, I either sub in a wire, or crimp the connector a little more.
Have you done any voltage testing? And how are you jumping it? Are you going straight to the starter, or on the battery terminals?
#4 nev OFFLINE
nev
  • 12 posts
Posted June 25, 2011 - 06:56 PM
Did you test the battery? My son had the same problem and it turned out to be a short. Drained the battery dead over night.
