Newbie here...Hello and take a look at what I just got.
bolens g154
36 replies to this topic
#16 ericjr16 OFFLINE
ericjr16
  • 1114 Thanks
  • 594 posts
Posted November 04, 2016 - 08:22 PM
You sir did AWESOME!! To get paid to get a sweet machine!! :)
#17 zippy1 OFFLINE
zippy1
  • 638 Thanks
  • 389 posts
Posted November 04, 2016 - 10:56 PM
Being you got it for a grand total of zero dollars, I thinks you can afford to stick a few into it making it a working tractor... :thumbs:
#18 jd.rasentrac OFFLINE
jd.rasentrac
  • 4979 Thanks
  • 4413 posts
Posted November 05, 2016 - 06:35 AM
:welcometogttalk:
#19 DaffyJeffy OFFLINE
DaffyJeffy
  • 13 Thanks
  • 9 posts
Posted November 05, 2016 - 10:54 AM
Thank you for all the responses, and views.  Here are more pics.  Including a good look at the broken flange on the transaxle.
  • HJR said thank you
#20 secondtry ONLINE
secondtry
  • 4989 Thanks
  • 2912 posts
Posted November 05, 2016 - 11:23 AM
Is there a matching flange on the other side  DON
#21 DaffyJeffy OFFLINE
DaffyJeffy
  • 13 Thanks
  • 9 posts
Posted November 05, 2016 - 11:29 AM
yep, it's just the one side that is broken.
#22 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted November 05, 2016 - 12:19 PM
The lower 3 point arms attach to a 7/8" steel rod. You can see the hole where it slides thru just to the right of the broken piece. There are 3 large bolts on the underside of the rear diff. Mine has a chunk of 3/4" steel plate bolted on there that extends out to make a 2" receiver hitch. It also supports the rod for the 3 point. You could patch the hole and add a plate to make a support.
#23 MiCarl ONLINE
MiCarl
  • 2660 Thanks
  • 1322 posts
I presume it's just a place that bracket that sticks down next to it bolts up?
I'd be tempted to cut/file an aluminum block to fit and have a competent welder attach it to the trans axle.
#24 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted November 05, 2016 - 12:25 PM
The cast piece that is broken off of it extends out to form a tube for the 3 point arms attachment rod. It extends from the hole you see to the right of the broken out piece, 1&1/4" back towards the center, right up against that bracket.
#25 DaffyJeffy OFFLINE
DaffyJeffy
  • 13 Thanks
  • 9 posts
Posted November 05, 2016 - 12:41 PM
thanks for those ideas guys, I'll definitely give them some consideration.
#26 Zekkjacen OFFLINE
Zekkjacen
  • 211 Thanks
  • 224 posts
Posted November 05, 2016 - 05:37 PM
I see you are looking to sell it on Craigslist.  If you have a use for the tractor, it is definitely worth keeping.
#27 DaffyJeffy OFFLINE
DaffyJeffy
  • 13 Thanks
  • 9 posts
Posted November 05, 2016 - 05:42 PM
Yeah I put it up just to see if it draws interest.  I'm really torn because on the one hand, I'm a pro handyman and this thing could be useful personally and on the job.  On the other hand I have several rebuild projects going already (a John Deere 110, a Johnson boat motor, and a Polaris sled I may start as well).  Too many fun things to rebuild and not enough time.  Maybe I'll keep the Bolens and part-out the JD 110.  I don't know.  Money talks and I'm somewhat broke right now.
Edited by DaffyJeffy, November 05, 2016 - 05:43 PM.
  • Bolens 1000 said thank you
#28 DaffyJeffy OFFLINE
DaffyJeffy
  • 13 Thanks
  • 9 posts
Posted November 07, 2016 - 07:33 PM
I took her for a little spin this afternoon.  Very impressive turn radius and the thing can climb like hell.  Perhaps I'll keep it after all and perhaps part-out my John Deere project.
  • Zekkjacen, ClassicBolens and propane1 have said thanks
#29 Zekkjacen OFFLINE
Zekkjacen
  • 211 Thanks
  • 224 posts
Posted November 08, 2016 - 12:54 AM
I like the way you think!  :love:
#30 ClassicBolens OFFLINE
ClassicBolens
  • 1527 Thanks
  • 516 posts
Posted November 08, 2016 - 09:05 AM
Wise choice!
Edited by ClassicBolens, November 08, 2016 - 09:05 AM.
