Air Filter help
6 replies to this topic
#1 BMW1 OFFLINE
BMW1
  • 12 Thanks
  • 41 posts
Posted November 03, 2016 - 08:11 PM
I posted this in Bobs Lawn and Garden tractor forum but only received two replies. Posted in this forum to see if anyone can help.
I have a B&S 253707-0325-91072511 engine that someone changed to have a Walbro carb 5-4993.
The air cleaner assembly did not contain an air filter.  It doesn't have a bolt/nut to hold the top on either.  The top simply flips up.
Does anyone know what air filter goes into the assembly below?  I couldn't find a number on the piece either.
Measurements and  pictures are below.
Outside measurements are all in inches and are approximate.
3 3/16 right to left
7 9/16 up and down
at the bottom, left side, the narrow piece before the curve is 1 1/2
at the top, right side, from top to start of curve is 3 3/4
The inside is odd. It's divided into what looks like two separate compartments.  Does a foam filter go on one side and a paper element in the other?
The right side of the air cleaner is about 1 1/16 right to left and 1 3/8 deep
The left side of the air cleaner is about 2 right to left and 3/4 deep
#2 GWest OFFLINE
GWest
  • 540 Thanks
  • 495 posts
Posted November 04, 2016 - 05:27 AM
See if this takes you to the engine operator manual.
http://bsintek.basco...7tH217FzoPu.pdf
There is an illustration there for the foam filter.
Garry
  • BMW1 said thank you
#3 old coot OFFLINE
old coot
  • 110 Thanks
  • 84 posts
Posted November 05, 2016 - 11:04 AM
wondering if napa auto parts could help you..they have helped me find filters for different things over the years
#4 64fleetside OFFLINE
64fleetside
  • 189 Thanks
  • 98 posts
Posted November 08, 2016 - 07:18 PM
If nothing pans out, cut a piece of foam to fit tightly in the housing, oil it some and go. Ive even bought foam filters that were too big and cut to fit.
Edited by 64fleetside, November 08, 2016 - 07:18 PM.
  • old coot and BMW1 have said thanks
#5 Bolens 1000 OFFLINE
  • 14,903 Thanks
  • 18,103 posts
Posted November 09, 2016 - 10:47 AM
Ive looked in all my catalogs as a dealer and cannot find anything on this filter, I think its actually from a Tecumseh but cant quite find one to match those specs.
#6 SimplyRad OFFLINE
SimplyRad
  • 1,019 Thanks
  • 785 posts
Posted November 10, 2016 - 09:07 AM
That air cleaner looks like it is for a vertical shaft engine and fits close to the shroud.
#7 BMW1 OFFLINE
BMW1
  • 12 Thanks
  • 41 posts
Posted June 18, 2017 - 06:54 PM
I finally found the filter. It's Briggs and Stratton part# 272922.
  • Cvans said thank you
