PK 1614 front blade
6 replies to this topic
#1 jjln50 OFFLINE
jjln50
  • 11 Thanks
  • 18 posts
Posted November 03, 2016 - 12:15 PM
My 1614 front blade usually works great but on occasion it will take about 30 tries to get the blade to raise. It is happening more and more regular. Any help? Thanks
#2 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted November 03, 2016 - 12:26 PM
Do you have a manual lift or hydraulic?  If hydraulic and you have enough fluid in the tank (which you probably do or it wouldn't raise at all) get down beside the machine and watch the linkage while you raise and lower to see what's going on that might be causing your problems.
  • jjln50 said thank you
#3 Glenn Ayers ONLINE
Glenn Ayers
  • 63 Thanks
  • 86 posts
Posted November 03, 2016 - 04:25 PM
Check the BELT
See if it starts slipping when you apply hoist.
  • Gtractor and jjln50 have said thanks
#4 MNGB ONLINE
MNGB
  • 2,134 Thanks
  • 1,413 posts
Posted November 03, 2016 - 09:24 PM
Yep check to see if the belt is slipping.
#5 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted November 04, 2016 - 04:29 AM
Wow, can you tell it's been a loooong time since I've owned one of these?  I completely forgot about the belt which more than likely is the culprit.
  • Alc and jjln50 have said thanks
#6 Alc ONLINE
  • 6,886 Thanks
  • 7,461 posts
Posted November 04, 2016 - 05:36 AM
Jeff I also had the set screw loosen up on the pulley that acted that way too if you find the belt isn't slipping . There's no high pitched squealing when it's under load ?  If so maybe the relief valve isn't adjusted for the correct pressure ? Not likely  but thought I would mention it . Here's when I did mine
  http://gardentractor...eded-adjusting/
  • MNGB and jjln50 have said thanks
#7 jjln50 OFFLINE
jjln50
  • 11 Thanks
  • 18 posts
Posted November 04, 2016 - 06:46 PM
Got looking closer today and found a adjustment on the passenger side of the pump mounting plate. It didn't adjust far enough  so welded a extension on adjusting bolt, worked great.
