John Deere 430 won't stay running
7 replies to this topic
#1 Jake OFFLINE
Jake
  • 237 Thanks
  • 133 posts
Posted October 31, 2016 - 04:26 PM
Yesterday I got a John Deere 430 today I run it around for 20 min or so and it quit start right back up then quit sometime it will run a min. Or two but not very well. Is there a pump between the tank and filter? And will a bad filter do this. It was running good this morning it was 30 and started right up.HELP thanks all Jake
#2 lyall OFFLINE
lyall
  • 1,893 Thanks
  • 1,470 posts
Posted October 31, 2016 - 05:30 PM
There should be a screen (filter) in the fuel tank on the end of the fuel pick up.
that is what the parts brake down show on site
http://jdpc.deere.co...?Origin=JDParts
Deere show two different tanks
hope this helps
  • Jake said thank you
#3 boyscout862 OFFLINE
  • 11,407 Thanks
  • 8,445 posts
Posted October 31, 2016 - 09:30 PM
Download the engine manual from our Manuals Section. Go through the Troubleshooting guide. It will take you step by step through the process to find the problem. Before doing that I woud check the fuel, fuel filter and the pump. The easiest way to check is to disconnect the line at the carb and put the end into a clean glass jar. Crank the engine over for a couple of seconds and see the quality and quantity of fuel that came out. Becarefull that there are no flames or sparks around you. If there is plentiy of clean fuel, the problem is probably else where. Two sneaky problems that can occur: the fuel lines swell closeing off the line, and the fuel tank cap doesn't vent causing a vacuum in the tank so that fuel can't come out.
First thing to try is to losen the fuel tank cap and run the engine. If it stays running, your problem may be the cap vent is plugged. if that doen't solve it, look at the other tests. Good Luck, Rick
Edited by boyscout862, October 31, 2016 - 09:32 PM.
#4 olcowhand OFFLINE
  • 38,017 Thanks
  • 30,439 posts
Posted October 31, 2016 - 09:45 PM
This is a diesel engine, so no carb of course.  There is an electric fuel pump between tank and filter.  You can pull the fuel line off at the injection pump, or loosen the bleed line, turn on the key, and see if there is fuel flow.  If not, either there is an obstruction, fuel pump or wiring faulty, or filter clogged.  This is glossing over, but first check for flow, then get back with us.
#5 Cvans OFFLINE
  • 5,773 Thanks
  • 5,734 posts
Posted October 31, 2016 - 11:19 PM
Check the breather on fuel tank cap. Tank needs to be vented properly before you can get fuel out of it.
#6 stiemmy ONLINE
stiemmy
  • 2,451 Thanks
  • 1,796 posts
Posted November 01, 2016 - 07:36 AM
I would check to see if the fuel system is completely sealed too. One little leak will cause air to enter the fuel system, and deisels don't like air.
#7 Bud W OFFLINE
Bud W
  • 274 Thanks
  • 257 posts
Posted November 01, 2016 - 11:18 AM
A buddy of mine worked on a 435 that had fuel issues. He had to remove the tank twice and clean the algae out. The second time, he replaced the pickup screen.
#8 Jake OFFLINE
Jake
  • 237 Thanks
  • 133 posts
Posted November 01, 2016 - 02:10 PM
Thanks all. Just put a new filter on sofar so good. I check the fuel flow going in and coming out of the filter an you could see a big difference when I get time I will fun it around and let you thanks
  • olcowhand and Cvans have said thanks
