56 Bolens ride a matic belt spring 1703575 needed
3 replies to this topic
#1 hddlh OFFLINE
hddlh
  • 54 Thanks
  • 97 posts
Posted October 31, 2016 - 08:19 AM
The belt spring p/n 1703575 is in ruff condition, rusted, broke in two spots, it kind works but would like to find replacement if possible.  Can the correct one or one that works be purchased and if so where?  Also the reverse disc comes no where close to drive pulley, could this be related to spring, it's almost 1/4" inch away so wear shouldn't be the problem I think.
My new project is another learning experience in mechanical devises!
thanks
#2 chieffan OFFLINE
  • 16606 Thanks
  • 9090 posts
Posted October 31, 2016 - 09:47 AM
About any hardware store will have a spring supply.  Find one as close as possible to the right length and a little stronger to allow for fatigue.
The reverse disc only goes into the drive pulley when the lever is pulled to the rear.  Other than that, no contact.
#3 hddlh OFFLINE
hddlh
  • 54 Thanks
  • 97 posts
Posted October 31, 2016 - 12:07 PM
Problem with reverse is the two never get closer than 1/4" even when in reverse.
#4 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted October 31, 2016 - 01:36 PM
Have pictures, I believe there is an adjustment that can be made
