Source for 1650A Front Clutch
#16
ONLINE
Posted December 15, 2016 - 06:54 PM
#17
OFFLINE
Posted January 10, 2017 - 08:34 PM
Yes, to a Kohler K341AQS.
olcowhand - I noticed you mentioned this motor. I've been researching clutches for the K341AQS but what I'm seeing is for a 1" shaft, whereas the motor I have is 1.125". I see a stamp on the front that says "K341" (without the "AQS"). Are we talking about two different motors?
#18
OFFLINE
Posted January 10, 2017 - 10:06 PM
Sounds like not the OE engine.olcowhand - I noticed you mentioned this motor. I've been researching clutches for the K341AQS but what I'm seeing is for a 1" shaft, whereas the motor I have is 1.125". I see a stamp on the front that says "K341" (without the "AQS"). Are we talking about two different motors?
- nrramse said thank you
#19
OFFLINE
Posted January 11, 2017 - 07:45 PM
I have a kohler engine off a 1650 that has the clutch. Let me check the shaft sizes this weekend and see if they match. I have no idea but I am pretty sure mine is a an orginal engine.
#20
OFFLINE
Posted January 16, 2017 - 10:14 PM
You may be right - Dad had the motor replaced in the mid 90's. Unfortunately, there's no decal or tag that says the model number of engine.
#21
OFFLINE
Posted February 01, 2017 - 08:04 PM
Have you located a a front electric clutch for your MF 1650,... yet? There is a used MF1650 electric PTO posting on EBAY from JOES OUTDOOR POWER.
Check it out.
#22
OFFLINE
Posted April 02, 2018 - 09:20 AM
Its been a while, but we finally reassembled the tractor! I thought I'd post back to put some closure on this thread.
I never did find a new OEM style clutch, but found an aftermarket one using the website https://www.stens.co...ic-pto-clutches. This website is great because it let me search by specs rather than tractor model (recall I may not have an OEM motor).
I used the part number from the Stens website to get a new Ox Clutch. Its a different design - the pulley is a little bit smaller than before, and the main shaft has a sideload now that it didn't have before. On the other hand, it cuts grass just fine!
- olcowhand, limebuzz, coldone and 1 other said thanks
