Sunstrand 15
6 replies to this topic
#1 Jake OFFLINE
Jake
  • 238 Thanks
  • 141 posts
Posted October 28, 2016 - 02:06 PM
I got a Sunstar rear and sunstrand 15 for a project can you change the direction the input shaft rotates? I wood like to run it off the pto Side of the engine. Thanks for any and all help
#2 Billy M OFFLINE
Billy M
  • 735 Thanks
  • 578 posts
Posted October 28, 2016 - 03:11 PM
You would have to check the pump bearing lube journals.  Pump bearing journals are usually lubed/fed from the low pressure side of the pump.  If ran backwards, the low pressure side will become the high pressure side and blow the outer shaft seals out.  The Sundstrand may or may not be designed like that.  I read about it years ago.  I've never had to tear that deep into one.  I'm sure someone more informed than I can confirm or deny that. I'm no expert by any means.  :D
Edited by Billy M, October 28, 2016 - 03:14 PM.
  • Jake said thank you
#3 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted October 28, 2016 - 03:30 PM
  According to the repair manual I have for it, all you have to do is remove the charge pump bolts and rotate the pump housing 180*. In a pic it shows markings on the housing stamped RH and LH. The rotation you want will read upright on the top. Depending on how you plan to use it I imagine you'll have to change the control linkage to get the RPM you want from each direction.
                                   HTH,
                                            mike
  • ducky, Jake and KennyP have said thanks
#4 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted October 28, 2016 - 05:06 PM
I have a Sunstar hydro & diff under Hogzilla running opposite direction from OE.  The charge pump housing has LF on one side, and RH on the other.  As said, just rotate 180* to change rotation.
#5 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted October 28, 2016 - 06:01 PM
I am with ol' stonebreaker and olcowhand.
I did it on my for wheel drive build.
  • olcowhand, Jake and ol' stonebreaker have said thanks
#6 KennyP ONLINE
  • 40,949 Thanks
  • 47,132 posts
Posted October 28, 2016 - 07:52 PM
That's nice to know since I have 2 of them now!
  • olcowhand and ol' stonebreaker have said thanks
#7 Jake OFFLINE
Jake
  • 238 Thanks
  • 141 posts
Posted October 29, 2016 - 05:33 AM
Thanks all for the help Jake
