Bolens 1053 Return to Service Project
528 replies to this topic
#421 Bolens 1000 ONLINE
  • 17322 Thanks
  • 18800 posts
Posted June 15, 2017 - 07:25 PM
Looking good
Wish I waited to restore mine now that we know the correct paint!!!
  • blackjackjakexxix, 29 Chev and logmillingman have said thanks
#422 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 19397 Thanks
  • 6576 posts
Posted June 15, 2017 - 07:30 PM
Looking good
Thanks.   Yes - I wish that my 1050's had the metallic paint instead of the leather brown as well but that will give me something to do when I am really bored.  I do love the metallic colour - it almost seems to change shade out in the bright sunlight depending on how you view it and the way the light reflects off of it.
  • Bolens 1000, blackjackjakexxix, TomLGT195 and 1 other said thanks
#423 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 19397 Thanks
  • 6576 posts
Posted June 17, 2017 - 04:54 PM
With a little help the engine took a leap of faith off of the engine stand and found its new home (at least for a while) in the tractor.  I opened the hood up so that it was resting on some old tires and set a couple of short pieces of wood about 1" thick across the frame rails and on top of the front axle support so that I could set the engine on the wood and have clearance to set the four spacers in place. I decided to remove the rear heat shield so it would not be in the way of setting the engine in place.  Once I had the engine sitting on the pieces of wood I set the two rear spacers in place and then started the rear bolts and removed the rear piece of wood.  Then I set the two front spacers in place, removed the front piece of wood and let the engine sit on the spacers - then I started the front bolts and tightened the vibration nuts up on all the bolts.  Hooked the hood stop link to the hood and the engine bracket and slowly closed the hood to make sure things would clear which they did.  I did a test fit of the rear heat shield and found out the hole I had made in it was not quite big enough to clear the bolt on the governor arm so the hole got enlarged with the help of a round file and then I touched up the paint and installed the heat shield along with the belt guard.
  • Bruce Dorsi, blackjackjakexxix, KennyP and 4 others have said thanks
#424 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 19397 Thanks
  • 6576 posts
Posted June 17, 2017 - 05:00 PM
I tried a pipe of 1" pipe and an elbow on to see how it would look for an exhaust pipe as the exhaust port is higher than the hood - it looks like it might clear but I am thinking of a couple of other options.  Set the other heat shield that the solenoid and regulator mount on in place and it should fit ok but I will leave it off until I figure out the exhaust.  Got the fuel tank mounted in place and I also installed the ammeter, light switch and ignition switch in the dash and took a couple of pictures with the hood closed.
Edited by 29 Chev, June 18, 2017 - 04:49 PM.
  • Bolens 1000, Bruce Dorsi, blackjackjakexxix and 6 others have said thanks
#425 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 3768 Thanks
  • 2017 posts
Posted June 17, 2017 - 05:22 PM
Sweet!
  • 29 Chev said thank you
#426 Chubien OFFLINE
Chubien
  • 648 Thanks
  • 399 posts
Posted June 17, 2017 - 09:02 PM
Looks like new!
Sent from my Nexus 9 using Tapatalk
#427 TomLGT195 OFFLINE
TomLGT195
  • 4155 Thanks
  • 2947 posts
Posted June 18, 2017 - 04:42 AM
Starting to look like a tractor ! Nice work!
#428 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 19397 Thanks
  • 6576 posts
Posted June 18, 2017 - 05:12 PM
I decided to take a stab at making an exhaust pipe - I studied the two pictures of the correct exhaust S pipe that Bolens1000 has posted on his web site to see how the original exhaust pipe was shaped - my thanks to him for posting them and sharing this information.  I thought about using some automotive 1-1/2" exhaust tubing and cutting it lengthwise and then squeezing it together so it would be a snug fit over a piece of 1" pipe but I figured that if I could shape something similar out of 1" pipe it would be stronger as the pipe is thicker than the tubing. I checked my stash and came up with two 1" pipe nipples - one was 3" and one was 4" long.  Unfortunately they were galvanized for plumbing applications - it is hard to find 1" black pipe fittings at the hardware store.  If you attempt to make something like this as I did make sure you grind as much galvanize coating off as you can and wear a good quality mask and weld it outside in a well ventilated area as galvanize fumes are poisonous to breathe.  I started with the 4" long piece of pipe and after threading it into the engine to determine where it would stop turning I marked it with a centre punch so I knew what spot would be up.  Then I referenced that mark so I knew which way I wanted to bend the pipe and cut several slits with a hack saw about 3/4 of the way through the pipe at about 1/4" intervals and then shaped the pipe to form a curve as you can see in pictures 3, 4 and 5.  Did a test fit on the tractor and added one more slit as can be seen in pictures 8 and 9.  Then I welded the slits back in with the mig welder outside while wearing a mask and after lots of nasty smoke I sanded the welds down with a flap wheel to see how things looked.  I also built up two spots at 180 degrees to each other that I sanded down to provide two flats that I could use a pair of vise grips on to turn the pipe.  I was happy with the results so I carried on - the insides of the pipe are not perfectly smooth as a result of the welding but should still let lots of exhaust gas to flow into the muffler without creating too much turbulance.
Edited by 29 Chev, June 19, 2017 - 08:24 AM.
  • Alc, Bruce Dorsi, blackjackjakexxix and 5 others have said thanks
#429 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 19397 Thanks
  • 6576 posts
Posted June 18, 2017 - 05:18 PM
I did some more slits at the threaded end of the pipe and tacked the 3" piece onto the end and welded and sanded the slit area - I also built up where the threads had been cut to make them as strong as the rest of the pipe.  Then I did some more slits on the second piece of pipe so it would bend back the other way, welded and sanded them.  Then I tried to do another test fit and found out I had to remove the dash support or the engine to start the pipe into the exhaust port - since two screws removed the dash support once the heat shield was removed the dash support came off.  I did two more slits at the first bend to get the bend a little sharper and then welded and sanded and wire brushed the welds.
  • Bolens 1000, Alc, Bruce Dorsi and 6 others have said thanks
#430 KennyP OFFLINE
  • 50116 Thanks
  • 52292 posts
Posted June 18, 2017 - 05:21 PM
Pretty neat looking pipe!
#431 Bolens 1000 ONLINE
  • 17322 Thanks
  • 18800 posts
Posted June 18, 2017 - 05:23 PM
Great Job on the pipe!
Looks very close to the original XK141 wisconsin elbow!
  • blackjackjakexxix and 29 Chev have said thanks
#432 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 19397 Thanks
  • 6576 posts
Posted June 18, 2017 - 05:24 PM
Did another test fit and was happy with the way things looked so I gave the pipe a quick splash of silver paint - it will probably burn off but will make it look pretty until I start the engine.  I installed the lock nut on the end before I painted it and since I had the pipe held on the threaded end with a pair of vise grips I figured the paint could dry just as good with the pipe threaded into the engine so I  threaded the pipe into the exhaust port.  I installed the dash support and verified the pipe cleared the hood and the muffler would not be too close to the hood to burn the paint or decals and it seems to have enough clearance so I took a few pictures of it with the hood closed and open.  The muffler tilts down and ahead a little bit but I think it should work ok.
#433 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 4977 Thanks
  • 2862 posts
Posted June 18, 2017 - 07:30 PM
NICE JOB !!!  :thumbs:
#434 logmillingman OFFLINE
logmillingman
  • 2164 Thanks
  • 896 posts
Posted June 19, 2017 - 02:05 PM
Really nice work!
#435 BOLENS-SIMONUK OFFLINE
BOLENS-SIMONUK
  • 12 Thanks
  • 9 posts
Posted June 19, 2017 - 03:32 PM
Looking good
