Bolens 1053 Return to Service Project
528 replies to this topic
#181 Bolens 1000 OFFLINE
  • 17293 Thanks
  • 18793 posts
Posted January 19, 2017 - 05:47 PM
Looking good Stew!
If everyone worked at the level you did there would be more tractors still around and less in the hands of the parts scrappers!
  • KennyP, WrenchinOnIt, TomLGT195 and 1 other said thanks
#182 KennyP ONLINE
  • 50024 Thanks
  • 52249 posts
Posted January 19, 2017 - 06:02 PM
Looking good Stew!
That's for sure!
  • 29 Chev said thank you
#183 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 19326 Thanks
  • 6549 posts
Posted January 19, 2017 - 06:33 PM
Looking good Stew!
Thanks - I am not sure that most people would want to invest the time and money into a project like this but it is good for keeping the mind sharp as to how I am going to repair the various parts and make them look like they did originally.
I thought someone would make a comment about my unusual support for the fender that I used while I was working on it or maybe I am just "nuts" for Bolens tractors.  :smilewink:
  • Bolens 1000, blackjackjakexxix, WrenchinOnIt and 1 other said thanks
#184 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5014 Thanks
  • 1201 posts
Posted January 19, 2017 - 07:03 PM
I was going call it the ol' peanut prop, to be used in conjunction with the beer bottle prop, both consumable , nice combo. AND nice work buddy !!!
  • blackjackjakexxix and 29 Chev have said thanks
#185 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3618 Thanks
  • 2329 posts
Posted January 19, 2017 - 08:05 PM
Stew sure has a special talent,unfortunately we don't all have it,way to go Stew
Edited by blackjackjakexxix, January 19, 2017 - 08:33 PM.
#186 Husky OFFLINE
Husky
  • 1508 Thanks
  • 1202 posts
Posted January 20, 2017 - 07:55 AM
Stew I am blown away at your workmanship. You have done and continue to do beautiful work. Thank you for taking time to post all the pictures and descriptions of what you are working on.
#187 KennyP ONLINE
  • 50024 Thanks
  • 52249 posts
Posted January 20, 2017 - 08:17 AM
Yeah! Your are an inspiration to us all!
#188 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 19326 Thanks
  • 6549 posts
Posted January 20, 2017 - 09:52 AM
Thank you all for your kind words - I have seen posts of your tractors and attachments and sometimes I am in awe of your projects and equipment - plus the knowledge that you people share so freely.  Thank you for allowing me to be a member of this site and share my little bit of "Bolens" fever with you.
  • blackjackjakexxix and KennyP have said thanks
#189 KennyP ONLINE
  • 50024 Thanks
  • 52249 posts
Posted January 20, 2017 - 10:18 AM
Every one of us here offer some type of help, no matter the form it is in.
  • blackjackjakexxix, TomLGT195 and 29 Chev have said thanks
#190 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 19326 Thanks
  • 6549 posts
Posted January 20, 2017 - 03:31 PM
Made a pair of "L" brackets to join the front of the fender to the frame tube covers - they were missing so I did not have one to use as a pattern- went with two pieces of 1" x 2-5/8" x 1/8" flat steel.  They are probably a little heavier than what was there originally but I figured the extra weight would come in handy some cold winters day when I needed a bit more traction.  Drilled a 5/16" hole in each of the brackets and mounted them to the covers, set the fender back on and marked the location of the bracket to the fender so that I could figure out where to place the lower bolt holes in the fender.  Once I had that done I removed the fender, drilled two 5/16" holes about 1" in from the edge and centred in relation to the marks, and then remounted the fender and marked out the location of the holes on the brackets.  Took an average of the marks and centred the holes in relation to the width of the brackets so they would be identical , drilled 5/16" holes and welded four 5/16" nuts to the brackets.  Enlarged and slotted the holes slightly in the fender pan and bolted it in place - had to bend the left side of the fender ahead at the lower outer edge to get it to look right for the tire clearance but all in all I am happy with the way it looks and fits.  Will have to get some shorter bolts for the brackets as the one inch ones I used are too long but they let me get things fitted.
  • Bolens 1000, Bruce Dorsi, blackjackjakexxix and 5 others have said thanks
#191 KennyP ONLINE
  • 50024 Thanks
  • 52249 posts
Posted January 20, 2017 - 03:53 PM
Zipping right along there!
#192 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 19326 Thanks
  • 6549 posts
Posted January 20, 2017 - 06:11 PM
Almost three months on this project and still only about half way there - good job I am not working at the Bolens factory as I would probably have been replaced with someone more productive - two tractors a year would not be considered a very good return on investment!  :rolling:
Edited by 29 Chev, January 20, 2017 - 06:12 PM.
  • Bolens 1000, blackjackjakexxix, KennyP and 2 others have said thanks
#193 KennyP ONLINE
  • 50024 Thanks
  • 52249 posts
Posted January 20, 2017 - 06:33 PM
Bet it'll be better than factory when your done!
#194 ClassicBolens OFFLINE
ClassicBolens
  • 1525 Thanks
  • 516 posts
Posted January 21, 2017 - 10:13 PM
But it will be a life long investment, because the way you're doing it, they're gonna be around for a good long time.
Edited by ClassicBolens, January 21, 2017 - 10:13 PM.
#195 Bolens800uk OFFLINE
Bolens800uk
  • 2643 Thanks
  • 1473 posts
Posted January 22, 2017 - 03:51 AM
Great work though and if you were running a restoration workshop that would be the norm ! As others have said, it will last a long time.
