Engine swap commences....few questions...
4 replies to this topic
#1 DZG OFFLINE
DZG
  • 419 Thanks
  • 362 posts
Posted October 24, 2016 - 02:10 PM
Finally got around to yanking the motor on my LT8...
20161024_145436.jpghow to print screen on pc
This is swap #2 in this tractor, i ripped the 8hp years ago to put an 11hp in, which promptly seized...so the 11 is get replaced with this...
20161024_145736.jpgimage upload no limit
Anyways, the thing fits like a glove, except on the starter side of the motor theres 2 pigtails on the new motor, the tractor, and old motor only had one, one pigtail had a female end, the other male, the tractor has a female, so i plugged the male one in, but im not sure what to do with the other??
Also, where can i find a larger pulley for the motor?
Thanks in advance
  • Traill95 said thank you
#2 tater195 OFFLINE
tater195
  • 1,873 Thanks
  • 1,247 posts
Posted October 24, 2016 - 02:18 PM
I believe one is for the stator/ charging system and the other is for the anti backfire solenoid on the carb. I have not played with the ohvs that much, so I could be wrong. Some have a 2 circuit stator, 1 for charging the battery and 1 for running the lights
#3 DZG OFFLINE
DZG
  • 419 Thanks
  • 362 posts
Posted October 24, 2016 - 02:53 PM
I did trace the wire and atleast one runs to the anti backfire solenoid. It should run with that unhooked shouldnt it?
#4 tater195 OFFLINE
tater195
  • 1,873 Thanks
  • 1,247 posts
Posted October 24, 2016 - 02:58 PM
Nope.
you can A) run a hot wire from the starter switch B) install an old style bowl screw or C) cut the tip off and put it back in.
If you go with option A make sure you have 12V while cranking, it wont start if you dont.
#5 DZG OFFLINE
DZG
  • 419 Thanks
  • 362 posts
Posted October 24, 2016 - 05:39 PM
Nope.
Im thinking switching to the old style bowl would work best, im guessing its a easy swap? Just pull and replace?
This is my first rodeo with electronic garbage
