2003 Ford F-250 Front hub assembly
14 replies to this topic
#1 SearsYellow OFFLINE
SearsYellow
    Mower Extraordinaire
  • 484 Thanks
  • 589 posts
Posted October 23, 2016 - 08:31 AM
My bearings are going bad in my 2003 Ford F-250. It's 4x4 with ABS. I went to the store to check on the part and everything is quite confusing. I got prices from 150-274.99. The 274.99 is a part from SKF. They tell me that it is the best part next to OEM. My whole problem is I don't want to spend 274.99 when there's a lower price for a hub. I indeed understand that I get what I pay for. O Reilly's has Mastercraft for 200 bucks. Could anyone give me some advice on this? Anyone had good luck with a certain name brand?
  • VintageIronCollector and Marty'70 have said thanks
#2 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,421 Thanks
  • 1,855 posts
Posted October 23, 2016 - 08:46 AM
For steering and suspension parts I LOVE Moog parts. Some parts are even greaseable where as the original Ford ones weren't and moog price for that look to be $230-280 they also have a 3 yr warranty as well.
  • SearsYellow and Marty'70 have said thanks
#3 VintageIronCollector OFFLINE
  • 1,421 Thanks
  • 1,855 posts
Posted October 23, 2016 - 08:47 AM
Looks like this is what you need.
#4 boyscout862 ONLINE
  • 12,541 Thanks
  • 9,040 posts
Posted October 23, 2016 - 09:03 AM
Checkout  http://www.rockauto.com/  . They tell you the level of quality and the price. I've been doing business with them for about 8 years and only had one problem which they made right.
I've saved alot of money with them and on occassion found that they had parts(for my 85 C10) that were not available anywhere else. Good Luck, Rick
  • Bmerf said thank you
#5 drbish OFFLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,358 posts
http://www.rockauto....partnum= 515020
147.00
Edited by drbish, October 23, 2016 - 09:04 AM.
#6 VintageIronCollector OFFLINE
  • 1,421 Thanks
  • 1,855 posts
Posted October 23, 2016 - 09:18 AM
good deal
#7 Marty'70 OFFLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 853 Thanks
  • 715 posts
Posted October 23, 2016 - 10:40 AM
When it comes to auto parts it is like tractor parts. You DO get what you pay for. Have found out over the years name brand is sometimes more than "paying for the name" wheel bearings are in that category for me. I go with timken if at all possible. Just my 2¢ worth.
Edited by Marty'70, October 23, 2016 - 10:47 AM.
#8 FixItCharlie OFFLINE
FixItCharlie
  • 518 Thanks
  • 336 posts
Posted October 23, 2016 - 01:39 PM
I just rebuilt the front axle on my 2001 F350 4X4. Replaced U Joints, Ball Joints upper & lower, & hubs along with brakes. I used Moog hubs from Advance Auto Parts. One thing I like about Advance Auto Parts is the ability to shop for the parts on line, find what store has them in stock, & picking them up at the store. Purchasing on line for store pickup also gives a 10% discount & sometimes more. The hubs on my truck were still Ok but I could not remove them because of corrosion, ended up getting Ball Joints to drop out & cutting them off & driving the hubs out with an air chisel. The lower Ball Joints were defective any way. The Moog Hubs come with the studs for installation many other hubs do not have these they have to be purchased separately. I wish you Good Luck with repair as I had many challenging days doing mine.
Charlie
#9 Bill 76 ONLINE
Bill 76
  • 1,892 Thanks
  • 1,178 posts
Posted October 23, 2016 - 01:56 PM
Stay away from O Reilly's unless you want to do the job again in a year. Napa is cheaper and better quality
#10 Alc OFFLINE
  • 6,745 Thanks
  • 7,397 posts
Posted October 23, 2016 - 02:23 PM
If you go with Rockauto I would go with one of there better brands I bought the middle cost wheel bearings for my Cavailer and both went bad within 6 months under 20k then went to Advance Auto each time for the replacement
#11 Alc OFFLINE
  • 6,745 Thanks
  • 7,397 posts
Posted October 23, 2016 - 02:25 PM
Doesn't your truck use a very heavy duty snap ring on the axle ?
#12 VintageIronCollector OFFLINE
  • 1,421 Thanks
  • 1,855 posts
Posted October 23, 2016 - 04:27 PM
our 2005 f350 did so it wouldnt surprise me if his truck does
#13 SearsYellow OFFLINE
SearsYellow
  • 484 Thanks
  • 589 posts
Posted October 23, 2016 - 04:31 PM
It uses a few snap rings.
#14 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,201 Thanks
  • 5,675 posts
Posted October 23, 2016 - 05:57 PM
:iagree:  :iagree:  :iagree:
I can't stress this enough-  DO NOT TIGHTEN THE AXLE BOLT WITH AN IMPACT!
Use a torque wrench as the instructions say.  (Ask me how I know?)
#15 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted October 23, 2016 - 06:40 PM
Rock auto. Saved enough with them on ball joints, tie rods, etc. (Moog complete rebuild), to replace all the u joints on the '95 ford F150 4x4; with change to spare. Bought Timken front hubs on the Trailblazer (both) for the cost of one locally; 50,000 miles with no issues. Parts are usually here in 3-5 days. :thumbs:
Edited by Bmerf, October 23, 2016 - 06:41 PM.
