How much does Your GT weigh?
21 replies to this topic
#1 KennyP ONLINE
  • 35,069 Thanks
  • 44,091 posts
Posted October 23, 2016 - 07:49 AM
While at the show, I went by the scale at the tractor pulls. Asked the guys if I could weigh Alice. 'Sure!' So up on the scales I went. I was surprised and so were they! Alice had the front suitcase weights and 3-point plow on, basic plowing setup. And this is what she weighs in at with me on her...........
1408 lbs.
That's a lot more than I figured!
  • Bolens 1000, olcowhand, Alc and 7 others have said thanks
#2 boyscout862 ONLINE
  • 11,838 Thanks
  • 8,680 posts
Posted October 23, 2016 - 07:55 AM
Kenny, I think that you may have to lose weight. Good Luck, Rick
  • Gtractor, KennyP, Arti and 1 other said thanks
#3 KennyP ONLINE
  • 35,069 Thanks
  • 44,091 posts
Posted October 23, 2016 - 08:11 AM
I'm down below 160, Rick! Much more and I have to stay inside when the wind blows!
  • DH1, MFDAC and boyscout862 have said thanks
#4 stiemmy OFFLINE
stiemmy
  • 2,527 Thanks
  • 1,827 posts
Posted October 23, 2016 - 08:39 AM
Kenny, just curious how does that 1408 pounds break down?
#5 KennyP ONLINE
  • 35,069 Thanks
  • 44,091 posts
Posted October 23, 2016 - 08:46 AM
First, that 3-point 12" plow is heavy. Got 80 pounds in my two front weights. Back tires are filled with WW fluid and have 80 pounds in wheel weights per side. One tire, wheel, fluid and weights is 200 lbs. My ~160 lbs. The rest is Alice.
  • MFDAC, boyscout862 and stiemmy have said thanks
#6 boyscout862 ONLINE
  • 11,838 Thanks
  • 8,680 posts
Posted October 23, 2016 - 08:55 AM
I, unfortunately, have 60 pounds too many. I would love to give them away. Good Luck, Rick
  • KennyP and propane1 have said thanks
#7 propane1 ONLINE
propane1
  • 7,986 Thanks
  • 3,861 posts
Posted October 23, 2016 - 09:04 AM
Tractor it's self is not that heavy. About 650/680 if my figurin is right.
Noel
#8 propane1 ONLINE
propane1
  • 7,986 Thanks
  • 3,861 posts
Posted October 23, 2016 - 09:13 AM
My lgt165 ford is 850 lb, so the manual says. The blower and riggin are about 300 lb. 200 lb weight on back. 50 in tire chains and cab. And me about 200 lb. never had anything on a scale. No wheel weights or loaded tires. 1600 lb all toll.
Noel
  • KennyP and CanadianHobbyFarmer have said thanks
#9 toppop52 OFFLINE
toppop52
  • 4,714 Thanks
  • 4,435 posts
Posted October 23, 2016 - 10:46 AM
My CC 3208 weighs 816 lbs according to Tractordata, with no attachments, hitch or deck.
#10 Cat385B ONLINE
    HAZMAT CAT
  • 13,138 Thanks
  • 9,617 posts
Posted October 23, 2016 - 11:16 AM
It doesn't matter, it's almost Thanksgiving. Then Christmas. We'll work on the weight issue on New Year's. Promise.
#11 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,611 Thanks
  • 914 posts
Posted October 23, 2016 - 11:50 AM
1408 lbs.
Explains why she plows so smooth!
  • KennyP and toppop52 have said thanks
#12 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,173 Thanks
  • 694 posts
Posted October 23, 2016 - 02:52 PM
I have misplaced my owners manual for the Bolens 1054, but I downloaded one for the 1050 and it says 645 lbs, should be about the same.  I have 40 lbs of RV antifreeze in each rear wheel and 25 lbs of home built weights on each side (130 lbs total).The plow and sleeve hitch combined should be another 200 lbs and I am around 180 lbs. Totals out to 1155 lbs ready to plow. It could use some more weight up front, it does not like to turn. I am actually surprised that Alice is that light ready to plow.
Jim
Edited by CanadianHobbyFarmer, October 23, 2016 - 05:27 PM.
#13 toppop52 OFFLINE
toppop52
  • 4,714 Thanks
  • 4,435 posts
Posted October 23, 2016 - 03:32 PM
I thought we were talking bare tractor weight. I have 150 lbs of wheel weights, sleeve hitch with electric actuator, front bracket with 80 lbs (not on unless needed). So it can weigh around 1100 plus any implementation.
#14 KennyP ONLINE
  • 35,069 Thanks
  • 44,091 posts
Posted October 23, 2016 - 03:59 PM
It surprised me it was so high. Gotta remember this is not a 'stock' tractor, so I guess I added more weight during the build.
#15 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,173 Thanks
  • 694 posts
Posted October 23, 2016 - 05:18 PM
I have read your build thread on Alice and she looks to be a very sturdy machine, a lot bigger than my tube frame Bolens. Your total weight including the front suitcase weights is only 253 lbs more than mine and I don't have front weights on it yet .
Jim
