Fuel valve and deck question
8 replies to this topic
#1 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted May 29, 2011 - 06:37 AM
I ran out of gas yesterday on the 318 and when switched to reserve it still didn't start . Blew into the lines and neither was below the fuel level . Filled the tank and all is fine but I'm wondering what happened to the reserve line in the tank . Has anyone had a switch or tank apart ? The other question is I raised the deck higher and noticed that it didn't stay level , the rear it higher then the front , I would have thought it should have .? Maybe it wasn't level before I raised it :blush2::blush2:
#2 MH81 OFFLINE
Posted May 29, 2011 - 08:46 AM
When you ran out of gas, were you on uneven ground and is there a fuel pump on it?
If the fuel was out of the line & it couldn't prime... or if the pump is weak and couldn't get it uphill?
Wish I could help you more.
#3 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted May 29, 2011 - 09:43 AM
The 318 has a 2 position fuel valve On & Reserve kind of like a motorcycle , almost seems like the pickup for the reserve has a hole or broke off inside the tank . It's not that big of a deal just will need to CHECK the fuel before using it !!!!!:wallbanging:
  • 14,811 Thanks
  • 15,500 posts
Posted May 29, 2011 - 09:48 AM
Al, If the deck isn't level when you rase it, it's not level when it's down. You need to get the tractor on a flat level surface and check it. I hope this helps.
#5 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted May 29, 2011 - 02:38 PM
There are 2 lines that run from the switch to the tank one for the reserve and one reg line most of the time they don't get used and the pickup falls off or clogs up I put new ones in my last tractor I put together because they fell apart.
#6 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted May 29, 2011 - 10:25 PM
my 318 will only run on reserve . it used to run on on and i switched it to reserve and all was good until i went back to on and it died .
  • 14,811 Thanks
  • 15,500 posts
Posted May 29, 2011 - 10:40 PM
Gary, Will your switch go completely around or does it have stops, so you can't go the wrong direction. I wonder if you went backwards and turned the valve to the blank side of the valve.
#8 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted May 29, 2011 - 10:50 PM
it has stops with off in the middle i think . id have to look at it again its been like this for a long time .
#9 Texas Deere and Horse OFFLINE
  • 14,811 Thanks
  • 15,500 posts
Posted May 29, 2011 - 11:04 PM
I had one that the stop was broken off and you could turn it the wrong way. You might want to pull the valve apart and see if it's got some junk in the line going into the main line at the valve connection. Or there could be junk in the tank that has settled down on the main line outlet.
