Going to tell you guys how to repair Tecumseh lme and lmh carburetor worn throttle shaft holes.
11 replies to this topic
#1 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted October 21, 2016 - 05:50 PM
No need to spend $30 bucks on bushings for these tecumseh carbs. Most of you will be able to do this for free. If your throttle shaft hole is worn on your carb . Take a shot .22mag shell, cut to length of the throttle shaft hole. Drill the hole in the carb with a 1/4" bit. Tap in the bushing you made from your shell. I have found that sometimes depending on the bit , the bushing will not be quite as tight. If this happens you can either leave it be free. It can't come out once the carb is back together or I use clear epoxy and put some on before I push it in. If you measure your 1/4" bits with a caliper you can find one that is going to make the piece you made from the shell tight by using calipers on the shell too. Once you have it in the inside diameter of the bushing may shrink. If this happens drill it with a 7/32" bit. Or you can use a steel brush in a drill with valve grinding compound to get it to where the throttle shaft pivots with no tight spots. You are now done and can re-assemble. Hope this helps some of you guys from tossing good carbs because they are surging.
Edited by Tecumseh power, October 21, 2016 - 05:58 PM.
  • DH1, limebuzz, MH81 and 6 others have said thanks
#2 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted October 21, 2016 - 06:02 PM
In extreme cases the bottom hole can wear also. This rarely happens , but this can be done on the bottom hole also.
  • Bruce Dorsi and Genem have said thanks
#3 DH1 ONLINE
DH1
    Electric Tractors
  • 5,378 Thanks
  • 5,609 posts
Posted October 21, 2016 - 06:27 PM
I have more or less done the same thing with a piece of 1/4 soft copper pipe.
  • MH81 and Tecumseh power have said thanks
#4 jms180 ONLINE
jms180
  • 1,631 Thanks
  • 1,623 posts
Posted October 21, 2016 - 06:35 PM
Nice piece of work good information
  • Tecumseh power said thank you
#5 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted October 21, 2016 - 06:37 PM
I tried that before but for some reason I can't remember exactly. Something didn't work right
Edited by Tecumseh power, October 21, 2016 - 06:44 PM.
#6 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted October 21, 2016 - 07:08 PM
They make bushings at any size u want!!!!
No offense, but why not go that route?
#7 DH1 ONLINE
DH1
    Electric Tractors
  • 5,378 Thanks
  • 5,609 posts
Posted October 21, 2016 - 07:11 PM
I used a rat tail or chainsaw file to fit the inside of the copper to the shaft.
Edited by DH1, October 21, 2016 - 07:11 PM.
#8 Xrperry ONLINE
Xrperry
  • 1,101 Thanks
  • 803 posts
Posted October 21, 2016 - 09:01 PM
it would give you a good reason to shoot the 22 also
  • adamjd200 and Tecumseh power have said thanks
#9 MFDAC ONLINE
MFDAC
  • 3,487 Thanks
  • 1,680 posts
Posted October 21, 2016 - 09:36 PM
There's a lot better ideas here than the one i had a few years ago, but it did work well. The throttle shaft was notched badly on my HH120 carb. I had "speedy sleeve" stuck in my mind on how to fix it. I used a broken car antenna tube for the sleeve. The bottom bore seemed fine yet. Drilled the top bore of the carb to the size of the sleeve. Carb was still working good a year ago when i had to part out the engine. I am going to put that carb on the Tech 10HP I have in my MF8E.
DAC
  • MH81, boyscout862, karel and 1 other said thanks
#10 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted October 21, 2016 - 10:03 PM
DAC
That isn't a bad idea! A bushing is a bushing. It worked for you!
  • MFDAC said thank you
#11 MH81 OFFLINE
Posted October 21, 2016 - 10:54 PM
A .22 brass. Good idea and lots of those around here and there.
I've bushed a couple carbs. Here is the worst one
http://gardentractor...gt/#entry219175
#12 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted October 22, 2016 - 12:02 AM
Make sure to use a .22 mag they are larger in diameter than a regular 22. Good job you did on the ones you fixed. Yes you do have to get creative. I was going to use a .222 but the .22 mag fits the shaft perfect
