New to me 1972 Deere 140
36 replies to this topic
#31 dropped82 ONLINE
dropped82
    Nut Case
  • 1,931 Thanks
  • 1,496 posts
Posted April 06, 2017 - 08:32 PM
The lowly tear streaming down my cheek isn't about the stupid deere, it's over the Ultima!
I guess I was a little insensitive towards the Simplicity people. I didn't take them to be whiners. Nothing intended towards all Deere people either. Ha....now I'm neutral, I think.
Eric
#32 Trav1s ONLINE
Trav1s
    Got points?
  • 2,792 Thanks
  • 3,923 posts
Posted April 06, 2017 - 09:00 PM
Ok... I suspect the linkage of the 140 and the Deutz were opposite and something was lost in translation.  Why not change the linkage of the hydro lever so that the action of the handle does the opposite action at the pump.  Hydros don't really care which direction they run other than reverse ground speed is limited (on Deere).  Did you use the entire linkage that came on the 140 or fab them together?  I am fairly confident this is the source of your problem.  How to make it work?  I am not much help without pics of the new rear end next to the original unit.
  • dropped82 said thank you
#33 dropped82 ONLINE
dropped82
    Nut Case
  • 1,931 Thanks
  • 1,496 posts
Posted April 06, 2017 - 09:03 PM
Yes you are correct on the linkage being reversed. Here the deal. The lift system is also reversed. Which will not operate in reverse. Plus I'd like the forward ground speed to be forward. I don't plow backwards haha. Charge pump flip will fix everything. It's not hard to do. Hardest part is sliding the rearend back to remove the driveshaft. The reason the linkage reverses the lever movement is due to the 140 having the charge pump set to flow the opposite direction. That's due to the driving gear on the opposite side of the driven gear in the rear axle compared to the duetz, Deere 300/400, and whoever else used the Peerless. The Dana in the closed frame required opposite input rotation for forward/backwards movement.
I'm actually glad it's like that. Easier than trying to make a modge podge of linkages to make it work. I still have the 140 neutral adjustments and full throw in the drive lever.
Eric
Eric
Edited by dropped82, April 06, 2017 - 09:08 PM.
  • KennyP and Trav1s have said thanks
#34 dropped82 ONLINE
dropped82
    Nut Case
  • 1,931 Thanks
  • 1,496 posts
Posted April 16, 2017 - 09:10 AM
As you can see, this build is going idle till after Ball Hollow plow day. Got some other priorities to get ready. After next weekend I'll be back on it. Happy Easter.
Eric
#35 dropped82 ONLINE
dropped82
    Nut Case
  • 1,931 Thanks
  • 1,496 posts
Posted May 18, 2017 - 07:19 PM
Well decided to mess around a little bit with the 140. Started it up and am moving. Just in reverse. I need to swap the linkage to correct that. I thought flipping the charge pump would do it. That only works if the engine is spinning the other direction. No big deal here to take it back. I've been having trouble with the lift circuit. Found out tonight the trouble was me haha. I was pulling the middle lever. Thinking it was like my 420 and operates the belly cylinder. Wrong!!! Pulled the inside lever and everything worked great. Back to swapping linkage. Will update soon!!!
Eric
Edited by dropped82, May 18, 2017 - 07:21 PM.
  • KennyP and SupplySergeant have said thanks
#36 dropped82 ONLINE
dropped82
    Nut Case
  • 1,931 Thanks
  • 1,496 posts
Posted May 22, 2017 - 07:44 PM
I had it out for a short drive and everything is good so far. Fixed a leaking line at the lift valve. Now I was pondering on what to do. Put the stock fender pan on it or add a set of split fenders and a pan seat. Make a "round fender" from it. What do you all think? Honest opinions are appreciated. It's clearly fairly custom right now. It'll have a cat. 0 3 point on the back. Would probably look good with some split fenders. On the other hand, install the fender pan and make it look somewhat factory.
Eric
Edited by dropped82, May 22, 2017 - 07:45 PM.
#37 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,480 Thanks
  • 825 posts
Posted May 22, 2017 - 08:15 PM
I vote split round fenders, the old school vibe seems like it goes with you and your Case's. Put an old John Deere "B" seat on it!
