New to me 1972 Deere 140
51 replies to this topic
#1 dropped82 ONLINE
dropped82
    Nut Case
  • 2,455 Thanks
  • 1,802 posts
Posted October 21, 2016 - 03:37 PM
Snagged this up a week or so ago. Came with a 4 way blade and some wheel weights. This is the 4th 140 I've owned. Finally got the setup I want. Late model (later hydro) H3. Got it running the other day. Runs great. No smoking or knocking. Only concern, it won't move. Lift works and the 2 valves are popped up. When I move the lever forward, it starts whining and I can hear the engine load up. Driveshaft is tight. When I rock it, I see the drums move slightly over the shoes. Brakes are not locked. What am I missing? I've pulled the fender pan to take a closer look. I'm stumped. Is there a valve that I'm missing? PO said the engine quit running in his garage and he didn't move it after that. Probably sat for the better part of a year.
Eric
  • Traill95 said thank you
#2 dropped82 ONLINE
dropped82
    Nut Case
  • 2,455 Thanks
  • 1,802 posts
Posted October 21, 2016 - 04:03 PM
Almost forgot the pics!!
Eric
  • Alc, Traill95, ericjr16 and 1 other said thanks
#3 propane1 ONLINE
propane1
  • 8,480 Thanks
  • 4,040 posts
Posted October 21, 2016 - 05:22 PM
Free wheeling valve some where. ?? Wish I had your 4 way blade for mine. Would like to get one some day.
Noel
#4 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted October 21, 2016 - 05:41 PM
Sweet :thumbs: Always wanted one, never found in my range yet....Can't help on the no move, I've never had a Deere below 80Hp on this farm (yet) so not familiar with the set-up in these. I learned a Bolen's can have a drive pin and/or out of adjustment gear set or both that can keep from moving but that is not a hydro. Cub that won't move is usually a roll pin in shaft or bad/dirty plugged valve(s) in top of unit. Can also be a completely plugged filter/wrong filter.
Lots of Deere expects on here to help, I watch the responses to try and learn.
Good Luck !
  • propane1 said thank you
#5 Trav1s ONLINE
Trav1s
  • 3,191 Thanks
  • 4,295 posts
Posted October 21, 2016 - 06:30 PM
Fluid good and full to level on dipstick? Release valves are not sealing. Soak them down with Pb blaster and let it sit overnight. Work them the next day.
  • johndeereelfman and ericjr16 have said thanks
#6 ericjr16 ONLINE
ericjr16
  • 1,051 Thanks
  • 575 posts
Posted October 21, 2016 - 06:44 PM
Looks good!!
#7 SupplySergeant OFFLINE
SupplySergeant
    Eggman's Dad
  • 1,721 Thanks
  • 971 posts
Posted October 21, 2016 - 06:59 PM
Does the later model still have the freewheel knob under the seat? I always forget to tighten it after I have to push her around.
Interesting treatment of the grill. I kinda like it!
#8 dropped82 ONLINE
dropped82
    Nut Case
  • 2,455 Thanks
  • 1,802 posts
Posted October 21, 2016 - 07:31 PM
I took the attempt at a 4020 look off. Looking for a grill and headlight panel. PO cut the original grill up. He said panel was busted so he made that. It does have the free wheel knob. I actually have that plate off to look at things so that not the problem. I have it on a jack now with the wheels up. They spin on the diff fine, but will not spin forward or backwards.
Eric
  • SupplySergeant said thank you
#9 dropped82 ONLINE
dropped82
    Nut Case
  • 2,455 Thanks
  • 1,802 posts
Posted October 21, 2016 - 07:32 PM
Noel
That 4 way blade is listed in the for sale/swap section. I already have one for my 420.
Eric
Edited by dropped82, October 21, 2016 - 07:32 PM.
  • Traill95 and propane1 have said thanks
#10 Traill95 OFFLINE
Traill95
    Traill95
  • 1,845 Thanks
  • 1,008 posts
Posted October 21, 2016 - 07:33 PM
Nice Score. good luck with it.  I have one and need the front 4 way blade  but haven't found but one and got out bid for that one.
#11 dropped82 ONLINE
dropped82
    Nut Case
  • 2,455 Thanks
  • 1,802 posts
Posted October 22, 2016 - 04:22 PM
Your only 77 miles away from me. I'm open for some offers on it. Shoot me a PM if your interested.
Eric
#12 dropped82 ONLINE
dropped82
    Nut Case
  • 2,455 Thanks
  • 1,802 posts
Posted October 25, 2016 - 04:56 PM
So and update here. Pulled the 2 check valves. They're good to go. Pulled a plug from the top that had a spring. I cranked the engine with each valve pulled and verified flow. Still won't move either direction. I guess I change the fluid and filter but think I'm going to be in the same spot just with clean fluid. Any suggestions here? When the 2 check valves are pushed down, you cannot roll the tractor at all. I'm at a loss here.
Eric
#13 KennyP ONLINE
  • 37,536 Thanks
  • 45,524 posts
Posted October 25, 2016 - 05:20 PM
I'm no Sundstrand guru so I'll see what the others say here as I have a 140 and parts of a 317.
#14 Trav1s ONLINE
Trav1s
  • 3,191 Thanks
  • 4,295 posts
Posted October 25, 2016 - 09:20 PM
Ok... are you sure the clutch is fully engaging?  Is the driveshaft spinning on the pump input shaft?
#15 dropped82 ONLINE
dropped82
    Nut Case
  • 2,455 Thanks
  • 1,802 posts
Posted October 25, 2016 - 09:29 PM
Yes..I have lift. The engine shows load when lever is moved forward. Nothing tells me driveshaft. It acts like my Case' do when fluid is going through the relief valve. Don't really know where that's at on this. Wondering if it's stuck or something.
Eric
  • Trav1s said thank you
