* * * * * 1 votes
Ford LGT 165 repower... Kubota d722
kubota ford lgt
130 replies to this topic
#121 pryan05 ONLINE
pryan05
    LGT
  • 449 Thanks
  • 251 posts
Posted June 04, 2017 - 06:35 PM
I decided to vent the side panels using perforated metal.  Shot coat of primer for now.
20170604_191403.jpg 20170604_191447.jpg I also plumbed cold air intake.
 A couple of rubber mounts added. I found the motor was deflecting too much and also cut down on vibration
  • olcowhand, Cvans, 48willys and 2 others have said thanks
#122 Cvans ONLINE
  • 5,884 Thanks
  • 5,802 posts
Posted June 04, 2017 - 07:47 PM
I found the same thing happening and went to larger ISO mounts. People said that the 3 cylinders could be mounted solid. Didn't take long to get this one mounted on rubber. Talk about a full body vibrator.
#123 pryan05 ONLINE
pryan05
    LGT
  • 449 Thanks
  • 251 posts
Posted June 18, 2017 - 06:57 AM
20170616_061550.jpg  I stripped all the five layers of paint off of the tin... The original blue then red, white, pink and a brushed on blue.  I few hours with the wire wheel and chemical stripper.   Primed and painted a first coat.  Decals are ordered.  I'm looking forward to finished results.
  • KennyP, Cvans, TomLGT195 and 1 other said thanks
#124 TomLGT195 OFFLINE
TomLGT195
  • 3,372 Thanks
  • 2,596 posts
Posted June 19, 2017 - 03:55 PM
With all the parts having all the same colors on them , at least you know they are all original to the tractor! what are you using for the paint? Rattle can or automotive type?
  • pryan05 said thank you
#125 pryan05 ONLINE
pryan05
    LGT
  • 449 Thanks
  • 251 posts
Posted June 22, 2017 - 04:57 AM
I'm using rattle can Krylon in Tru blue.  I start off with a rattle can high build primer.  The panels and the grill turned out really good, the hood was a different story,  After the I painted it the first time I wasn't happy with some of the imperfections so I filled them in with body filler,  When I went to paint it I guess the paint wasn't cured yet and is bubbled in some spots.  So I took it back down to steel were it bubbled and painted it again.  And the other day I mowed the lawn without any panels on the tractor and it ran 40 degrees F cooler than with all the panels installed.  So i decided to cut some of the grill openings than I welded on the hood and drill and cut four slots.  So.. it needs to be painted again but this time I'll wait for the paint to cure.  I'm also waiting for the decals to come in, once they are installed I like to clear coat over top of them.  Pictures will be posted when it all done.
#126 pryan05 ONLINE
pryan05
    LGT
  • 449 Thanks
  • 251 posts
Posted July 03, 2017 - 06:23 PM
I finally got it all painted, decals installed and assembled.  I'm happy with the results, the clear coat needs a bit of buffing but that's all in the details.  I installed some reflective noise insulation on the inside of all the panels.  It helps with the noise and the heat.20170703_161456.jpg 20170703_161519.jpg 20170703_161536.jpg 20170703_161536.jpg 20170703_161548.jpg 20170703_161602.jpg 20170703_161629.jpg 20170703_161646.jpg
  • olcowhand, KennyP, Cvans and 4 others have said thanks
#127 KennyP ONLINE
  • 34,718 Thanks
  • 43,759 posts
Posted July 03, 2017 - 06:31 PM
That is a sweet looking tractor!
#128 Cvans ONLINE
  • 5,884 Thanks
  • 5,802 posts
Posted July 03, 2017 - 06:59 PM
That looks nice enough to park in the living room.  :thumbs:
#129 Cub 1650 OFFLINE
Cub 1650
  • 158 Thanks
  • 98 posts
Posted July 04, 2017 - 05:05 AM
You did a great job on that tractor.
#130 Austen ONLINE
Austen
  • 1,272 Thanks
  • 769 posts
Posted July 19, 2017 - 04:35 PM
Looks great! Nice work!
#131 olcowhand ONLINE
  • 38,473 Thanks
  • 30,602 posts
Posted July 23, 2017 - 07:52 PM
Very nice work!  Watching your repower project come along helped get me back into my Allis repower.  Thanks!
  • KennyP and pryan05 have said thanks
