* * * * * 1 votes
Ford LGT 165 repower... Kubota d722
kubota ford lgt
139 replies to this topic
#136 pryan05 ONLINE
pryan05
    LGT
  • 617 Thanks
  • 342 posts
Posted September 24, 2017 - 04:39 PM
To get my new shaft in I had to unbolt the rear again. Royal pain that I hope I don't have to do again.
Yep, just pulled the motor out or disconnected everything but the electrical and the fuel lines.  I had to raise it with a chain fall high enough to wiggle the drive shaft out.  I should have put a large 10 pin connector on the electrical so I can just unplug and lift the whole motor out.
  • Cvans, TomLGT195 and Mark 149 J. have said thanks
#137 pryan05 ONLINE
pryan05
    LGT
  • 617 Thanks
  • 342 posts
Posted October 06, 2017 - 07:46 PM
Moving dirt with the Ford-Bota
  • olcowhand, KennyP and TomLGT195 have said thanks
#138 Cvans ONLINE
  • 6,458 Thanks
  • 6,053 posts
Posted October 06, 2017 - 08:45 PM
Nice video. You're sure not working the engine at all.  :thumbs:
  • pryan05 said thank you
#139 jpswift1 OFFLINE
jpswift1
  • 536 Thanks
  • 485 posts
Posted October 06, 2017 - 10:15 PM
I finally got it all painted, decals installed and assembled.  I'm happy with the results, the clear coat needs a bit of buffing but that's all in the details.  I installed some reflective noise insulation on the inside of all the panels.  It helps with the noise and the heat.attachicon.gif20170703_161456.jpgattachicon.gif20170703_161519.jpgattachicon.gif20170703_161536.jpgattachicon.gif20170703_161536.jpgattachicon.gif20170703_161548.jpgattachicon.gif20170703_161602.jpgattachicon.gif20170703_161629.jpgattachicon.gif20170703_161646.jpg
I can't believe I haven't seen this rebuild thread until now.  This tractor is absolutely stunning!  It looks like it came from the factory like this.  You do amazing work and this machine is better than any brand new garden tractor on the market today.  EXCELLENT WORK!!!
  • Cvans, TomLGT195 and pryan05 have said thanks
#140 KennyP ONLINE
  • 37,450 Thanks
  • 45,472 posts
Posted October 07, 2017 - 04:13 AM
Looks like it's working real good!
