Am I thinking correct on my v belt length
6 replies to this topic
#1 Tecumseh power OFFLINE
Tecumseh power
  • 1,479 Thanks
  • 1,115 posts
Posted October 19, 2016 - 04:49 PM
I acquired a free sears custom snowblower it was missing half the mount so I made my own. I also made my own extension pulley for the engine. So I can't go off of what the original size would be. As the distance between my pulleys maybe slightly different. Anyways they are 5" pulleys 24" apart. By using the math I come up with needing a 63.7" belt. Which would be a 64". But I will have to get a 65" to give it enough slack for the tensioner to kick it on and off correct? If I get a 64" it will be tight all the time. Am I right?
Edited by Tecumseh power, October 19, 2016 - 04:50 PM.
#2 drbish OFFLINE
drbish
    Collecter
  • 1,557 Thanks
  • 1,361 posts
Posted October 19, 2016 - 05:08 PM
http://gardentractor...d-pulley-sizes/ you can check your math by this Briggs release or read down to see the link to put your numbers in
  • Tecumseh power said thank you
#3 secondtry ONLINE
secondtry
  • 1,906 Thanks
  • 1,390 posts
Posted October 19, 2016 - 05:11 PM
I would think it will need more than 1" slack to disengage properly. Don
#4 Tecumseh power OFFLINE
Tecumseh power
  • 1,479 Thanks
  • 1,115 posts
Posted October 19, 2016 - 05:40 PM
Maybe I should go with 2" extra
#5 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted October 19, 2016 - 06:28 PM
I would use the old rope trick. Wrap a rope around the pulleys and make a mark. Measure the rope for the length; get the next size longer and the next size up. Try the shorter one first. It doesn't take much extra belt length to release. The local Family Farm will take the belts back if they have not been run. I have found that the Kevlar belts will stretch a little. Good luck.
  • Alc and Tecumseh power have said thanks
#6 lrhredjb OFFLINE
lrhredjb
  • 700 Thanks
  • 572 posts
Posted October 20, 2016 - 05:29 PM
Make sure you get the correct width belt also, i.e. 3/8, 1/2, 5/8 in. for the pulleys you are using.
  • Bmerf said thank you
#7 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted October 20, 2016 - 06:26 PM
The amount of slack is a consideration, but you must also plan on where the slack should occur.
Belt guides should be installed and adjusted to retain the belt on the pulleys, but also to  direct the slack to be around  the drive pulley, preventing belt creep.
