Honda GXV620
weak spark
4 replies to this topic
#1 inthehollar OFFLINE
  • 1 posts
Posted October 19, 2016 - 10:36 AM
Can anyone help me? I have a Hustler Fastrk z with a Honda GXV620 on it. I cannot get a strong spark on either plug.
I have done the following - new coils, new plugs, new plug caps, new rectifier, unhooked every kill switch on it and swapped the coils from cylinder to cylinder and then back again. I cannot get a good spark on either plug. I can get a spark testing light to light up but still a very weak spark at the plug.
Can the kill switch diode cause issues with a weak spark? I have unhooked the wires to the coil from the diode and still nothing.
Does the kill diode have to be hooked up and working properly to get proper spark?
I am beyond irritated!
#2 jms180 ONLINE
  • 1,551 Thanks
  • 1,591 posts
Posted October 19, 2016 - 12:59 PM
Robert@Honda can help. He usually hangs out at LawnWorld
#3 glgrumpy OFFLINE
  • 8,652 Thanks
  • 7,941 posts
Posted October 20, 2016 - 08:04 AM
Is there an oil  pressure sensor on these engines?  Maybe it is bad or wire off, or low oil?   Only had little honda 4hp's myself, they had that switch.
#4 massey driver ONLINE
massey driver
  • 1,431 Thanks
  • 1,580 posts
Posted October 20, 2016 - 08:55 AM
When you say new coils , did you buy them new or are you talking about a used coil. The new coils come with the ign wire but not the caps if I remeber correctly.I had a 20hp v twin one time and it used to eat coils for some reason. The coils are on the outside of the flywheel and are always live.They need a ground to kill them. If you've disconneted all the wire's that run to the coils you should have good spark..
This maybe off the mark but does this mower have a electric clutch on it. The electric clutch can and will ground out the ign if its shorted.Try disconnecting the wire to the electric clutch to see if it will run.
#5 jimbobbillyray ONLINE
  • 2,955 Thanks
  • 2,848 posts
Posted October 20, 2016 - 04:11 PM
checked the ground wire/grounding on it yet?
