Another weird idea from me.......need comments.
5 replies to this topic
#1 propane1 OFFLINE
propane1
  • 8,729 Thanks
  • 4,134 posts
Posted October 17, 2016 - 05:19 PM
I am thinking about putting a liner in one of my tractor tires. The liner will be an old tube. I would like to glue the liner/old tube to the inside of the tire, then install a air holding tube in the tire. Any ideas????? Or what would you use for a liner????
Another strange question/idea from,
Noel
#2 poncho62 ONLINE
poncho62
  • 1,767 Thanks
  • 1,669 posts
Posted October 17, 2016 - 05:21 PM
Why do you feel you need a liner between the tire and tube?
  • boyscout862 and propane1 have said thanks
#3 propane1 OFFLINE
propane1
  • 8,729 Thanks
  • 4,134 posts
Posted October 17, 2016 - 05:42 PM
Tire has cracks and rubs on tube, then causes hole, which causes flat tire. Tire needs replacing, but can't afford that, so , I figued a liner would help the bad tire along for a awhile longer.
Noel
#4 HDWildBill OFFLINE
  • 8,975 Thanks
Posted October 17, 2016 - 06:04 PM
That will work just fine.  Back when I did a lot of Bicycling and we got a flat we would take a $1 bill and wrap it around the tube so the puncture in the tire would not pinch the tube.  Also On MC wheels that use a tube I will put a patch over the puncture so it doesn't pinch a new tube, but I always put a new tube in.
  • propane1 said thank you
#5 Bill 76 ONLINE
Bill 76
  • 1,950 Thanks
  • 1,196 posts
Posted October 17, 2016 - 06:26 PM
I don't see any reason why it wouldn't work , a bit of glue to  hold it to the tire while assembling it and the tube should hold in it place when it's aired up . I usually dust a little talcum power on the inner tube to keep it from getting any folds in it when I air it up.
  • oldedeeres and propane1 have said thanks
#6 glgrumpy OFFLINE
  • 8,622 Thanks
  • 7,926 posts
Posted October 18, 2016 - 08:25 AM
Isn't that what they call Booting?  Sort of a hunk of rubber, kinda glued in, usually because the ag tire had big crack or rim edge going bad? Used to be a common thing to do, but not so much anymore. How about some filler material over in into the bad areas also, like silicone or similar?
