STIHL LINE TRIMMER QUESTION
3 replies to this topic
#1 farmer john OFFLINE
farmer john
  • 1,775 Thanks
  • 902 posts
Posted October 17, 2016 - 08:07 AM
Hello all I have a stihl line trimmer that I want to convert to handle bar grips, its an fs 90 the new throttle has a cable and 2 wires one goes to the coil the other is blue and I think its the ground as the old cable was longer and was screwed to the body after the carb. I am assuming it worked as throttle and off, so would the blue be ground ??
#2 HDWildBill OFFLINE
  • 8,975 Thanks
Posted October 17, 2016 - 08:42 AM
Black is usually ground but since you didn't mention what the other wires color is.  I would think one would have a spade connector and the other a round connector and that would dictate where each wire went.  If they don't have any connectors then I don't see where it makes much of a difference where each wire goes since it is just and on/off switch.
  • tractorgarden said thank you
#3 farmer john OFFLINE
farmer john
  • 1,775 Thanks
  • 902 posts
Posted October 17, 2016 - 10:05 AM
one wire was blue one black, the black has the locking connection on it for the coil the blue has a female spade end on it
#4 MH81 OFFLINE
Posted October 17, 2016 - 07:38 PM
Blue should be the coil then and the black should be the ground.
