kohler 331?
9 replies to this topic
#1 dodge trucker OFFLINE
dodge trucker
  • 2,448 Thanks
  • 3,131 posts
Posted October 16, 2016 - 08:11 PM
I have had several K321 model Kohler engines over the years, but never saw or heard of a Kohler K331.  none of my Kohler books even list this. was it an engine marketed elsewhere?
The engine that sparked my curiosity is on an old looking Miller welder.
#2 shorty ONLINE
shorty
  • 5,496 Thanks
  • 5,267 posts
Posted October 16, 2016 - 08:20 PM
Never heard of it. Could it have been a special for a certain manufacturer?
#3 EricFromPa ONLINE
EricFromPa
  • 3,670 Thanks
  • 3,118 posts
Posted October 16, 2016 - 08:42 PM
There pretty hard to come by but they did make a K330 and K331 12.5hp.They are a physically larger engine.173 lbs and 36.6 C.I.
Seen a couple on old Economy Power King tractors from 1964-1965 and a few on old generators from the late 50s early 60s.They were the only single cylinder Kohler with an oil pump.
Apparently the Only parts that's interchangeable from any other Kohler engine is the Cam cover gasket and Points cover gasket.There similar size to the 16hp K341.
Edited by EricFromPa, October 16, 2016 - 08:46 PM.
  • Alc, KennyP, tractorgarden and 2 others have said thanks
#4 Bolens 1000 OFFLINE
  • 14,987 Thanks
  • 18,140 posts
Posted October 16, 2016 - 08:53 PM
They are kind of an odd duck in the kohler family, only used in Gen sets and a few PK models from what I have seen.
  • tractorgarden, boyscout862 and dodge trucker have said thanks
#5 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted October 16, 2016 - 09:30 PM
I have two Power King K-331 tractors, they have gobs of torque.
#6 dodge trucker OFFLINE
dodge trucker
  • 2,448 Thanks
  • 3,131 posts
Posted October 17, 2016 - 07:15 AM
so them would any parts still be available for these?
#7 Trav1s OFFLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted October 17, 2016 - 08:37 AM
Looks like a pressurized oiling system in the video.  Bet those last for-ever!
#8 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted October 17, 2016 - 09:20 AM
not unless you find NOS.
  • EricFromPa and dodge trucker have said thanks
#9 EricFromPa ONLINE
EricFromPa
  • 3,670 Thanks
  • 3,118 posts
Posted October 17, 2016 - 10:49 AM
After doing quite a bit of digging I found that K330 / K331 piston, rings, valves, valve guides, valve springs, head gasket and rod bearing are the same as used in the K660 / K662.Oil pump may be the same to but don't quote me on it.
K660 / K662 are hard to find parts for to but not nearly as much so as the K330 / K331.
Weakest part on the K330/331 is the oil pump drive gear.Cold Weather starting using 30wt oil will cause the gear to strip eventually because good old 30wt is really thick (almost like tar) when the temps drop.Might be better to install a block heater or run 5W-20 or 5W-30 or a good 15w50 synthetic oil.
Edited by EricFromPa, October 17, 2016 - 11:01 AM.
  • Alc and tractorgarden have said thanks
#10 Bolens 1000 OFFLINE
  • 14,987 Thanks
  • 18,140 posts
Posted October 17, 2016 - 01:54 PM
I would imagine a good portion of them are still available, If you have your spec and serial number I can quote you pricing/availability
