Use of resistor spark plugs
plugs x700 series
6 replies to this topic
#1 Zimmersci OFFLINE
Zimmersci
  • 2 posts
Posted October 15, 2016 - 08:16 AM
Getting new X739. I get a small amount of motor static on my mobile phone when listening to music while I mow. If I substitute in resistor spark plugs will I gum up anything?
Thanks
Deere 2025 FEL-B
Cob Cadet 1440
Stork bringing new X739😍
#2 toppop52 OFFLINE
toppop52
  • 5,456 Thanks
  • 4,863 posts
Posted October 15, 2016 - 08:35 AM
No. May not lose the noise, either, radio waves can come from multiple sources. Just jangling a bunch of keys creates radio noise, but it's a good place to start.
#3 jimmy G ONLINE
jimmy G
  • 1,267 Thanks
  • 805 posts
Posted October 15, 2016 - 10:43 AM
The spark plug wire is the source of noise, works like an antenna, resistor plugs will make the signal stronger, resistor plugs hold back energy and load the coil until enough energy is created to force spark through supreshion wires,before supreshion wires everything made noise, it may or may not cause arcing at the coil if you use supreshion wire's, my 1947 AC B has them for this reason but has auto type coil so no problems
#4 chieffan ONLINE
  • 10,898 Thanks
  • 6,922 posts
Posted October 15, 2016 - 01:20 PM
I use a radio ear muff set and works good for both purposes.
#5 boyscout862 ONLINE
  • 13,437 Thanks
  • 9,384 posts
Posted October 15, 2016 - 01:25 PM
Zimmersci, welcome to GTT. Relax and enjoy the site. Good Luck, Rick
#6 Zimmersci OFFLINE
Zimmersci
  • 2 posts
Posted October 21, 2016 - 08:57 PM
UPDATE
in researching the Kawasaki motor in the X700 series, they come EQUIPPED with NGK resistor plugs.
#7 jimmy G ONLINE
jimmy G
  • 1,267 Thanks
  • 805 posts
Posted October 21, 2016 - 11:06 PM
That means you all ready have suppression wire's, their is an aftermarket add on suppressor for radios, they were also installed in GM's HEI inginions and look like a points condenser
