mower deck spindle removal
7 replies to this topic
#1 bill3t OFFLINE
bill3t
  • 49 Thanks
  • 89 posts
Posted October 14, 2016 - 05:08 PM
i busted my spindle hiting a rock mowing. removed spindle asembly from deck.took off pully. shaft not coming out easily. must be some rusty holding it on. probably gona lube and pound it thru. if salvagable will weld  it back together.b
#2 MNGB ONLINE
MNGB
  • 1,462 Thanks
  • 1,052 posts
Posted October 14, 2016 - 08:22 PM
Hi its best to use a press to remove the spindle shaft its a press fit into the bearings, if the shaft broke at the blade attach part  a new spindle shaft will be needed as the shaft is pressed into the blade attach and then welded. Good luck with it, I repaired one of mine this summer I'm lucky in that I have a good friend that works in a machine shop he fabricated a shaft and welded it then I reassembled it using the press in my shop.
  • bill3t said thank you
#3 bill3t OFFLINE
bill3t
  • 49 Thanks
  • 89 posts
Posted October 15, 2016 - 05:56 PM
I got a new hardware bolt . going to try machine keyway slot. and weld t- to it before spending alot of $$$.b
#4 MNGB ONLINE
MNGB
  • 1,462 Thanks
  • 1,052 posts
Posted October 15, 2016 - 06:30 PM
have you measured the bolt that was my original plan but found that bolts are undersize they are not a full .75" and the bearings just slope around on it.
#5 bill3t OFFLINE
bill3t
  • 49 Thanks
  • 89 posts
Posted October 16, 2016 - 01:43 PM
yeah my bolt stock is undesized also.just found some solid 3\4 rod that has good diameter for berings. my go see the machinst also.b
  • MNGB said thank you
#6 MNGB ONLINE
MNGB
  • 1,462 Thanks
  • 1,052 posts
Posted October 16, 2016 - 03:05 PM
That will work, I had some .75 axle stock but when my friend went to machine it they accidentally cut the threads undersized for a self locking nut so they made a new one and it turned out good, they pressed the shaft into the blade mount and TIG welded it in place.
#7 bill3t OFFLINE
bill3t
  • 49 Thanks
  • 89 posts
Posted October 20, 2016 - 04:42 PM
i finaly got my diy shaft completed. got a new die to make threads. use the pully as a guide to start cuting threads straight. clamped die to pully. worked good. b
#8 MNGB ONLINE
MNGB
  • 1,462 Thanks
  • 1,052 posts
Posted October 20, 2016 - 05:57 PM
Sounds good Bill you should have it repaired in no time.
