Mower deck question
8 replies to this topic
#1 Rainier OFFLINE
Rainier
  • 682 Thanks
  • 557 posts
Posted October 14, 2016 - 04:44 PM
The mower deck on my h14 is getting a make over. Looking at the diagram it shows a retainer that goes between the sling and lower bearing. The shafts I have are not grooved to place a clip. So the way they were is with the bearing riding on the sling. Is this ok or should I look into getting different shafts? The hole assembly always seems a little lose when everything is put together.
Mower deck # 18423
#2 ClassicBolens OFFLINE
ClassicBolens
  • 1527 Thanks
  • 516 posts
Posted October 14, 2016 - 05:42 PM
There is no groove in the shaft for the retaining ring. The retaining ring essentially acts as a spacer and was ultimately replaced with a thrust washer on later higher serial numbered decks.
  • Bolens 1000, Bruce Dorsi, Rainier and 1 other said thanks
#3 Rainier OFFLINE
Rainier
  • 682 Thanks
  • 557 posts
Posted October 14, 2016 - 05:49 PM
Here is a picture of the brake down. I don't see a purpose for the retainer clip.
#4 Rainier OFFLINE
Rainier
  • 682 Thanks
  • 557 posts
Posted October 14, 2016 - 05:52 PM
Ok so should I install the retainer clips, or should I get some thrust washers to put in there place?
#5 ClassicBolens OFFLINE
ClassicBolens
  • 1527 Thanks
  • 516 posts
Posted October 14, 2016 - 06:00 PM
Just use the retaining clips. They basically just keep the dust caps from rubbing the bottom of the housing.
  • Bolens 1000 and Rainier have said thanks
#6 Rainier OFFLINE
Rainier
  • 682 Thanks
  • 557 posts
Posted October 14, 2016 - 06:01 PM
300 for pounds! No wonder I am always having it come lose!
  • chieffan said thank you
#7 ClassicBolens OFFLINE
ClassicBolens
  • 1527 Thanks
  • 516 posts
Posted October 14, 2016 - 06:04 PM
150 inch pounds on top bolt first, 300 inch pounds on bottom. I always use a dab of threadlocker.
  • Bolens 1000, Rainier and chieffan have said thanks
#8 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted October 14, 2016 - 06:09 PM
:ditto: what classicbolens said!
  • Rainier and chieffan have said thanks
#9 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22761 Thanks
  • 7524 posts
Posted October 15, 2016 - 12:26 PM
The clips (snap rings) also serve to keep the spindle shaft in place if you have the belt off and the deck upside down and remove the blade and hub - otherwise, with the weight of the pulley, gravity can allow the shaft to slide out of the bearings under the right conditions.
  • Rainier said thank you
