Cat 0 3 point hitch, Sears 3 point hitch
6 replies to this topic
#1 Greasy6020 ONLINE
Greasy6020
  • 1,476 Thanks
  • 1,399 posts
Posted October 13, 2016 - 08:24 PM
Are they any different?
I just bought a Sears/roper/Moto Mower tractor, has Sears 3 point hitch.
Is it any different than regular cat 0 3 point hitch?
What are the differences? Is there a way to make it "standard" cat 0 3 point hitch?
I'd rather not chase single brand use implents all across the countryside just to do some work...
  • chieffan said thank you
#2 MiCarl OFFLINE
MiCarl
  • 2,024 Thanks
  • 1,050 posts
Posted October 13, 2016 - 08:49 PM
All of the Sears implements I've seen are not true cat 0.  The lift pins are set much closer together and they use a different style top link.  I recently purchased a Roper tiller set up for Sears 3 pt. and had to make an adapter to use it with my cat 0.
Around here you'd have better luck finding attachments for the Sears 3 pt. than a cat 0 anyhow.  I regularly see Sears plows and cultivators on craigslist.
Of course if you're looking for new implements I'm not aware of anything in production for either hitch.  All the new garden tractor implements seem to use a sleeve hitch.
Edited by MiCarl, October 14, 2016 - 07:03 AM.
  • Alc, chieffan and Greasy6020 have said thanks
#3 MH81 OFFLINE
Posted October 13, 2016 - 09:44 PM
Cat 0 and Sears Sub 0 are Not interchangeable.
Once you get a couple pieces of Sears stuff, you'll be able to measure and adapt a lot of stuff. Brinly adapters were built too.
  • ducky, Alc, chieffan and 1 other said thanks
#4 KennyP OFFLINE
  • 38,337 Thanks
  • 45,913 posts
Posted October 14, 2016 - 07:06 AM
Maybe this can explain things. This is a screenshot of a Sears 3-point blade. Notice item #14. the 3-point hooks onto this.  The top link mount is forward of the lower links. And the lower links are only 12" wide.
This is my Cat-0 3-point plow. Notice the top link mount is even with the lower links, which are 18" wide.
  • Alc, CRFarnsworth, TomLGT195 and 1 other said thanks
#5 york0060 OFFLINE
york0060
  • 310 Thanks
  • 146 posts
Posted October 14, 2016 - 08:33 AM
  These are the pins I made a several years ago so I could use my Sears attachments on my Cat 0 tractor. Worked great.
  • Alc, KennyP, KC9KAS and 1 other said thanks
#6 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted October 14, 2016 - 08:52 AM
No need for me to say the Sears 3 points are different....you already know that.
:nothingtoadd:
  • Greasy6020 said thank you
#7 KennyP OFFLINE
  • 38,337 Thanks
  • 45,913 posts
Posted October 14, 2016 - 08:53 AM
Need a real short top link also.
