Found a 448
7 replies to this topic
#1 Alberta Bolens OFFLINE
Alberta Bolens
  • 769 Thanks
  • 349 posts
Posted October 12, 2016 - 08:42 PM
I was out at a farmers place in the spring deliving some product.  In his Dads shed was an dust covered 448 with tiller.  We had a chat and I picked it up tonight.  Hasn't run in 5 or 6 years steering is shot.  Its all there, under the dirt and dust.  Some clean up and TLC should be good.
Photo as I found it and at home on my trailer.
How do you rotate the photos?
Edited by KennyP, October 14, 2016 - 06:07 AM.
Adjust Gravity
  • Gtractor, 101 senior, Cvans and 5 others have said thanks
#2 glgrumpy OFFLINE
  • 8,610 Thanks
  • 7,920 posts
Posted October 13, 2016 - 07:18 AM
Nice model. Should be easy fix, but might have to tear down a bit to get whole steering shaft out if need to replace a gear on it, or the shaft. Some grind the end of shaft off below the gear and slide it off, with shaft still in tractor. Worst part is getting the steering wheel off most times. Kinda humorous how all the sod/grass is still stuck on tiller from last use. Put away Wet then? heh!
#3 ssmewing OFFLINE
ssmewing
  • 50 Thanks
  • 59 posts
Posted October 13, 2016 - 07:59 AM
I have a good steering shaft left from a parts tractor if that is a part you need. I did already sell the sector gear. I do have the whole plate that bolts to the frame.
#4 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,668 Thanks
  • 2,143 posts
Posted October 13, 2016 - 08:12 AM
:thumbs:
  • KennyP and HANKG have said thanks
#5 Alberta Bolens OFFLINE
Alberta Bolens
  • 769 Thanks
  • 349 posts
Posted October 13, 2016 - 09:09 PM
It runs.  Hooked up the booster cables, primed the carb.   :dancingbanana: It fired after couple of cranks and after a minute of priming it cought and run on the gas in the tank.  5 year old gas.  It was still strapped to trailer.  It spun the wheels both forward and reverse and will lift the tiller.   :dancingbanana:
It does need a good cleaning, oil leaks repaired.  General TLC Think has good potential.
#6 KennyP ONLINE
  • 38,352 Thanks
  • 45,921 posts
Posted October 14, 2016 - 06:08 AM
I fixed the pics! Glad it runs again!
  • Alberta Bolens said thank you
#7 mac102004 ONLINE
mac102004
  • 317 Thanks
  • 389 posts
Posted October 22, 2016 - 07:08 PM
awesome little tractor. I never seen too many GT's when I lived in AB, but there sure was a lot of bigger Case farm tractors to be seen.
#8 dropped82 ONLINE
dropped82
    Nut Case
  • 2,501 Thanks
  • 1,818 posts
Posted October 23, 2016 - 09:02 PM
A lot of times the steering shims need moved. In the Case operating manual is instructions on how to do so. Shims are there in the form of washers. Just a matter of moving them from one side of the gear to the other. That's of course given nothing is stripped.
