I recently bought a skid of stuff, including a bunch of "New Old Stock" Brinly implements and eight sets of front wheel weights. The weights don't have a relief cut on the inside to clear the spindles on most GT's and shipping on them is crazy, so I was thinking they would be sitting here for a while. I was getting ready to make some concrete weights for my new pair of disc's when the lightbulb went on. I made a quick trip to the hardware store for some bolts and then got busy. Most of the steel brackets were included on the skid of stuff I bought, the plywood for the trays on the disc's is from an A-frame sign that got hit by a snowplow. All of the weight brackets on the Brinly stuff is bolted on, no permanent mods. They are all set up now to hold up to 80lbs each (160lbs total on the tandem disc). The weights just slip onto the bolts. I didn't add anything to the plow, it works fine just as it is, but I thought I would include it just to show all my sleeve hitch implements. I also just picked up a new sleeve hitch for my Bolens tube frames. The red one is my home built one, the white one is the one I got today.
Neat idea Jim, but I was wondering if the disks are on wrong or am I not seeing correctly in the second and third picture as compared to the first picture? Nice collection of attachments.
I agree. 2nd and 3rd pic has all the blade dish going the same way on the back gang. The top left blades need to be dish in in both pics. Nice looking set of equipment. Don't think you will need much if any weight on that spike harrow.
I was a bit confused about the comments on the disc's there for a second, but DH1 is correct, the first picture was taken from the front and the other two are from the rear. It does have the same hitch on both ends, so I can see where you would get that idea.
I tried the spike harrow unweighted and it didn't work well at all. I tried it again with 50lbs on it and it worked much better. It actually comes with a long carriage bolt and bracket to hold a cement block on top for weight.I like my new setup better though.
We are dealing with a whole different set of rules North of the border. Pics upload in every way but right. I think Gravity up there is different from ours.
Great idea on the use of the weights. That's a lot of nice stuff. I have the same set of tandem disc's & they work great. I use one 18" cement block on each...looks ugly but works.
Related Threads
Garden Tractor Forums
951.2K posts
49.2K members
Since 2010
