help me settle a friendly debate....
21 replies to this topic
#1 DZG OFFLINE
DZG
  • 609 Thanks
  • 525 posts
Posted October 10, 2016 - 06:10 AM
Me and my buddy were talking in his garage last night, we are very "mechanically competitive" and got to debating the merits of his four wheeler.
I believe it to be a honda foreman, 750CC, he claims about 50hp, 4x4, etc, its a pretty stout quad.
Anyways, he swears up and down and sideways, it could drag more weight on a dead sled pull then my dads 48 Farmall Cub could.
Granted, the cub is far from tbe stoutest tractor out there, but i highly doubt it would get shown up in a brute strength competition against his quad.
The quad weighs about 750lbs, the tractor close to 1500, the tractor also has loaded tires and ag lugs, compared to the four wheelers general purpose tires.
I know hes got a huge hp advantage, but do you think it can actually put more wheel torque/pull down then the tractor?
Discuss please :)
  • MH81, Canawler and chieffan have said thanks
#2 MH81 OFFLINE
Posted October 10, 2016 - 06:34 AM
I would think it would be interesting to try.
4wd and HP will be an advantage in his case, but I still think the tractor would be the victor. It's what it was designed to do.
Before there were lawyers, they used to settle disputes like this with a good chain and a line on the ground.
  • KennyP, HDWildBill, boyscout862 and 2 others have said thanks
#3 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,282 Thanks
  • 9,771 posts
Posted October 10, 2016 - 07:17 AM
I go with the Cub. I'm guessing it's got better gearing.
  • chieffan said thank you
#4 jabelman OFFLINE
jabelman
  • 2,218 Thanks
  • 1,592 posts
Posted October 10, 2016 - 07:25 AM
it's all in the gears
#5 olcowhand ONLINE
  • 41,052 Thanks
  • 31,392 posts
Posted October 10, 2016 - 07:30 AM
I'm going Cub. Tires, weight, and gearing all on it's side.
  • OldBuzzard and chieffan have said thanks
#6 Cvans ONLINE
  • 6,636 Thanks
  • 6,125 posts
Posted October 10, 2016 - 07:33 AM
Tractor. Rear tires loaded? Tire tread? Gravel, dirt, or blacktop? How low is the first gear on the Cub?
4x4. Tire tread? Any extra weight carried?
Tough to answer without all the facts.  :(
#7 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,973 Thanks
  • 4,408 posts
Posted October 10, 2016 - 07:50 AM
I'll wait for the video... Should be a good one. :thumbs:
  • MH81, Alc, HDWildBill and 1 other said thanks
#8 SimplyRad OFFLINE
SimplyRad
  • 1,092 Thanks
  • 835 posts
Posted October 10, 2016 - 07:55 AM
Hp isn't always an advantage when compared to torque. The gearing and the weight factor will be an advantage.
#9 chieffan ONLINE
  • 10,105 Thanks
  • 6,621 posts
Posted October 10, 2016 - 08:06 AM
Been answered in his post.   The tractor is a gear drive and the 4 wheeler is a sip-o-matic and geared much higher.  Dead sled pull are done on dirt, never heard of one on blacktop or gravel, regardless that part would be equal for both units.  Start with a loose chain and watch that 4 wheeler squirm like a snake in the grass backwards.  Just my opinion.  Only one way to settle it.  Best 2 out of 3.
  • Cvans said thank you
#10 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted October 10, 2016 - 08:11 AM
The Honda Foreman 750 has a tow-rating of 850lbs --manufacturer specifications.
The Farmall won't even get out of bed in the morning to tow 850lbs.  It's tow-rating is somewhere between 1,500 and 1,600 lbs, based on the Nebraska Tractor Tests: Circa 1947 and 1946
You also have weight, (Stock, dry Cub weight is close to 1,500lbs, and some weigh upwards of 2,800lbs, depending on the equipment they were ordered with) gearing, tire height, drawbar height, and tread to your advantage.
It's like comparing the tow capacity of a Dodge Neon (132-230hp) to that of a Case MX80C (82hp).
  • MH81, tractorgarden, HDWildBill and 1 other said thanks
#11 DZG OFFLINE
DZG
  • 609 Thanks
  • 525 posts
Posted October 10, 2016 - 08:16 AM
He doesnt disagree that id pull him in a tug of war, but he thinks pulling a dead sled (basically steel with weight dragging over the dirt) he could move more.
My opinions pretty much aligned with yours, i know what that little tractor is capable of, but he thinks anything built before the year 2000 is junk lol.
Maybe ill cut an old heating oil barrel in half and fill some 55 gal drums with water or dirt....and of course...set up a camera
  • Alc and Cvans have said thanks
#12 MiCarl ONLINE
MiCarl
  • 2,008 Thanks
  • 1,047 posts
Posted October 10, 2016 - 08:20 AM
It's going to look a lot like this: https://youtu.be/kA0E7kRhd6M
  • Cvans and DZG have said thanks
#13 OldBuzzard OFFLINE
OldBuzzard
  • 7,018 Thanks
  • 4,790 posts
Posted October 10, 2016 - 08:26 AM
I'm thinking the same thing.
Weight and traction will overcome HP any day as this vid proves.
https://www.youtube....h?v=BeDLX9hzPoA
ETA:  Looks like MiCarl found the vid before I did  :D :D :D
Edited by OldBuzzard, October 10, 2016 - 08:27 AM.
#14 karel OFFLINE
karel
  • 2,072 Thanks
  • 1,384 posts
Posted October 10, 2016 - 09:10 AM
Quads aren't made for pulling.
  • Dane in PA said thank you
#15 pick-to-stone OFFLINE
pick-to-stone
    Living in the past
  • 366 Thanks
  • 500 posts
Posted October 10, 2016 - 09:39 AM
Horse power doesn't matter it's all about weight and gearing I only now this do to are 464h John Deere when it Brock down on a up hill road
