Any tips or tricks?
3 replies to this topic
#1 JohnDeere110 OFFLINE
JohnDeere110
  • 215 Thanks
  • 91 posts
Posted October 09, 2016 - 07:59 PM
Does anyone have any tips or tricks for plowing with my JD 110. I plowed with it for the first time this spring and it was alittle rough.
Any advice is appreciated
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted October 09, 2016 - 09:13 PM
Rough how?
  • Gtractor said thank you
#3 JohnDeere110 OFFLINE
JohnDeere110
  • 215 Thanks
  • 91 posts
Posted October 10, 2016 - 07:11 AM
Rough how?
Well the plow wouldn't lift the entire way up so I'm guessing something in the lift springs needs replaced and also the drive belt would slip so I'm guessing that this is just simple things to fix that I'm overlooking.
#4 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted October 10, 2016 - 09:10 AM
Make sure you're using OEM JD belts.  Also, your variator could possibly use adjusting.
Lift problem sounds like you're spring assist isn't helping you enough, or your lift is out of adjustment.  There should be an adjustment knob on the rear of your tractor, where the pivot point is --if you're using a SQF.
Once you get them set up, they really work well.
