* * * * * 1 votes
Bolted the engine in the Junkyard Economy tractor.
30 replies to this topic
#16 KennyP OFFLINE
  • 37,424 Thanks
  • 45,461 posts
Posted October 09, 2016 - 04:44 PM
Nothing like the first ride on a tractor!
  • classic and MNGB have said thanks
#17 classic ONLINE
classic
  • 5,166 Thanks
  • 2,229 posts
Posted October 09, 2016 - 04:58 PM
I had to go for another ride before dark, heh! Still lots to do to get it wrapped up, so I will be busy next week on it. Got to be ready for the snow and I have to haul more firewood.
  • KennyP and MNGB have said thanks
#18 MiCarl ONLINE
MiCarl
  • 1,911 Thanks
  • 1,019 posts
Posted October 09, 2016 - 05:38 PM
Looks good.
Warning though:  If you spend all your free time riding it you'll never get finished.
  • KennyP, classic and MNGB have said thanks
#19 classic ONLINE
classic
  • 5,166 Thanks
  • 2,229 posts
Posted October 09, 2016 - 06:03 PM
Ha, now that's a fact! I had my fun for the day, so now it's back to work on it.
#20 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
first rides of any restoration always stick with you one of the good things in life. I still remember that day like it was yesterday when I finished my 65 mustang, windows down, a boom box blasting queensryche and up the road I went, we basically cut that car in 1/2 and welded all new rear sheet metal frame rails etc..
the butterflies if everything was going to be ok with out anything breaking. it was one the best experiences rebuilding a car like that, that was almost 20 years ago. I miss that car sold shortly after that.
  • Alc and classic have said thanks
#21 classic ONLINE
classic
  • 5,166 Thanks
  • 2,229 posts
Posted October 09, 2016 - 06:29 PM
I went through the same thing Jay back in 1990. Most of my friends were driving while I was working on my 70 SS 396 Chevelle. I worked every odd job I could and rebuilt my first big block for that car. It was the first car that I put on the road and I'll never forget that day. I got a speeding ticket to really burn that memory into my brain. The funny thing was that I couldn't keep myself from smiling, and it's a strange cool feeling. I must have looked like I lost my marbles,driving around with that grin on my face, heh.
  • Alc and BigF30 have said thanks
#22 SNUFFY OFFLINE
SNUFFY
  • 187 Thanks
  • 268 posts
Posted October 10, 2016 - 08:37 AM
It`s looking good Classic......!!
  • classic said thank you
#23 classic ONLINE
classic
  • 5,166 Thanks
  • 2,229 posts
Posted October 10, 2016 - 04:03 PM
The seat is painted and the wheel weights are on. The dash and starter generator are next. This seems never ending...
#24 Cvans ONLINE
  • 6,455 Thanks
  • 6,052 posts
Posted October 10, 2016 - 08:08 PM
Looks like your making good progress to me.
#25 classic ONLINE
classic
  • 5,166 Thanks
  • 2,229 posts
Posted October 10, 2016 - 08:27 PM
I have made progress Cvans, but it seems to take so much time to get so little done. I don't think an hour is as long as it use to be, heh!
  • Cvans said thank you
#26 classic ONLINE
classic
  • 5,166 Thanks
  • 2,229 posts
Posted October 11, 2016 - 06:05 PM
So today I took a bracket from an Allis B10 and a square head bolt from an old telephone pole, to make my starter generator bracket and belt tensioner. I cut the flat plate off of the bracket and had to weld all of the holes shut. I drilled the holes where needed and got the starter generator mounted where it needed to be, what a pain. I chased the threads on the bolt, cut the head off of it, ground a flat on it, and drilled a hole in the end. I dug up a very small pulley for the starter generator and installed it. I had a used link belt laying around, so I used that to set things up. I had to temporarily install the dash to make sure everything would work out. All is good, so now I can clean up everything and put the new bearings and brushes in the starter generator. I have to make a simple battery mount and I can wire the simple electrical system. Another step almost completed.
  • Alc, KennyP, Cvans and 1 other said thanks
#27 Cvans ONLINE
  • 6,455 Thanks
  • 6,052 posts
Posted October 11, 2016 - 08:03 PM
Your going to appreciate the work you put into that.
#28 Alc OFFLINE
  • 6,741 Thanks
  • 7,395 posts
Posted October 11, 2016 - 08:16 PM
Your generator bolt looks better then the factory ones !
#29 classic ONLINE
classic
  • 5,166 Thanks
  • 2,229 posts
Posted October 11, 2016 - 08:44 PM
If the company put the time into the production tractors like I have put into this thing, they would have closed up shop early on, heh! I think alot of us put quite a bit of time into these projects, but it's fun to see the results and either put them to work or haul them off to shows. I work like a snail with the limited tools I have on hand, but I'm slowly gathering more. The PK'S are simple tractors built out of simple common materials. This is one reason why they are quickly becoming a favorite. Thanks for the compliment Alc. The adjuster was simple to make and didn't take much time at all. Getting the bracket just right was a bit difficult, though.
#30 Alc OFFLINE
  • 6,741 Thanks
  • 7,395 posts
Posted October 12, 2016 - 05:43 AM
I'm going to have to copy your adjust at some point . The s/g on both the PK and Jim Dandy have regular V-belts and are at the limit of adjusting , it should be easier to make a new adjuster then splitting the tractor / trans to replace the belts
