Looking for some help with on when to apply either fall and winter fertilizer and over seeding grass seed or weed and feed fall and winter blend. Not sure which I'm going to do but I had alot of crabgrass and creeping charlie this year and it killed out alot of patches of grass. I'm located in south centeral WI to give you an idea on temprature conditions. Thinking I may dethatch and ariate before doing this, also what about leaf clean-up after this is done? Thanks, Dave S
Fall and winter fertilizer, over seeding
#1
OFFLINE
Posted October 08, 2016 - 08:30 AM
- chieffan said thank you
#2
OFFLINE
Posted October 08, 2016 - 09:48 AM
I rake up any leaves that have dropped. Aerate heavy. Lime. Fall fertilizer. Fescue and some rye. I try and do mine in mid to late September. I do winterizer just before Thanksgiving depending on the weather.
In the spring hit it with crabgrass preventer. I do it two times--the second about six weeks after the first. Later I use a selective herbicide like Bayer or Ortho for weeds and crabgrass. As I am outside each day, I take a couple of minutes and pull by hand anything that pops up.
You can't let leaves lay on your new grass. It will kill it out.
Also you can't do weed and feed and overseed at the same time. Reseed in the fall and start your weed battle next spring.
Go to the Scott's website and signup. You will get updates based on your zip code telling you what to do when. I resisted Scott's for years but it works.
In my experience it takes three years to get a yard into shape. Good luck.
#3
ONLINE
Posted October 08, 2016 - 10:41 AM
A lot of the information from Scott's, Earl May, etc. is for town/city size yards. Their products work but one cannot afford their stuff when you have 1.5 A yard . I go to the local fertilizer company, like Crop Production Services, and get what I need in the bulk. Usually go with what they recommend. They can analyze a soil sample for you also. Get it in 5 gal plastic pails. Takes about 6 to do the whole yard. For the weed control I spray. Use a tank on the back of a tractor with the 5' boom mounted out front with 4 nozzles. Mounted right above the wheels and directed forward. Can control it around shrubs, etc. but need a quit morning or evening.
#4
OFFLINE
Posted October 08, 2016 - 12:43 PM
#5
OFFLINE
Posted October 08, 2016 - 12:50 PM
