weight limit for a JD 400 garden tractor 3 point hitch
5 replies to this topic
#1 Saber20189 OFFLINE
Saber20189
  • 8 Thanks
  • 22 posts
Posted October 07, 2016 - 05:13 PM
I am mounting a 3 point hitch to my JD 400.  Let's say I have the weights necessary to lift with the hitch and now I need to know what the limitations are for the hydraulic cylinder.  I have a 48" grader blade and it is quite heavy.  My Snapper 1855 handled it very well but at the same time I would like to know what what the limitations are before I try other implements without blowing some gaskets.
Does this make sense?
#2 BigFlash OFFLINE
BigFlash
  • 248 Thanks
  • 134 posts
Posted October 07, 2016 - 05:24 PM
I'm not sure what you mean about blowing gaskets? If your wondering wether or not it will lift it. I say hook it up and try it. Either it will lift it or it won't. Every thing in the hydraulic system is designed to handle the pressure the pump can produce.  If you worried about over working the tractor itself. Again the best way to find out is to try it.
#3 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,743 Thanks
  • 1,906 posts
Posted October 07, 2016 - 06:57 PM
As with most hydraulic systems, there's pressure relief valves. That prevents things blowing up or out. I'm guessing that 400 will lift 4 to 500 lbs readily. Maybe not fast on the upper end but it will do it. Like was already said. Hook it up and try. It'll either do it or not.
Eric
Edited by dropped82, October 07, 2016 - 06:57 PM.
#4 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted October 07, 2016 - 09:08 PM
I don't believe it will blow a gasket.
Hydro cyls, use O-rings
Good luck, and cheers!
Edited by stiemmy, October 08, 2016 - 09:00 AM.
#5 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted October 07, 2016 - 09:14 PM
I believe MF cat 0 was rated at 400lbs.
#6 Saber20189 OFFLINE
Saber20189
  • 8 Thanks
  • 22 posts
Posted October 08, 2016 - 12:24 AM
Thanks guys.  I will take your advice and just see what it will do.  The 400 cylinders look great.  So I will give them a chance to show me what they can do.
Sabe
