mulcher replacement repair
4 replies to this topic
#1 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted October 07, 2016 - 06:05 AM
At the end of last summer my mulcher died so put it aside , but now im in spring i am now to be needing it again so toed it into the shed and checked it fuel &  tank was clean same with the carbie ,
so proceeded to the spark removed the top keyway and key good so then checked the stator hmmm DEAD old points , went on a hunt found a I C type and replaced with it
the old 1 >>post-62113-0-69567800-1475837984.jpg , thats the best thing i have done for the engine it now performs way better
its a 5 HP late 70's early 80's briggs & stratton will check the date of it
post-62113-0-15613700-1475838281.jpg << all fixed
Shane
Edited by KennyP, October 07, 2016 - 06:42 AM.
Adjust Gravity
  • Alc, KennyP, boyscout862 and 1 other said thanks
#2 SimplyRad OFFLINE
SimplyRad
  • 1,021 Thanks
  • 790 posts
Posted October 07, 2016 - 07:48 AM
Does that chip branches.
#3 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted October 14, 2016 - 03:30 AM
upto 2 in pretty much limits it depends on if soft wood too but still safe at 2 in
Shane
#4 SimplyRad OFFLINE
SimplyRad
  • 1,021 Thanks
  • 790 posts
Posted October 14, 2016 - 08:21 AM
My 8 hp Simplicity will do 3" but only in short bursts.
#5 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted October 15, 2016 - 03:51 AM
this 1 is the best 1 i have used  & i have had a fair variety of mulchers but mostly electric types , and yes can only feed the branches in , in short feeds or it will stall it , give it time to chop up
Shane
