Little to no spark.
7 replies to this topic
#1 SimplyRad OFFLINE
SimplyRad
  • 1,370 Thanks
  • 982 posts
Posted October 06, 2016 - 08:59 AM
Was out checking if there was any spark on my 3410 and could just barely see it with an occasional good spark. Would it be better to replace the coil on the engine or getting an external coil? I know the external is easier but time is not a problem just whether I want to try heating my shed to do it.
#2 Bolens 1000 ONLINE
  • 15,555 Thanks
  • 18,319 posts
Posted October 06, 2016 - 09:07 AM
what model / brand engine is this?
#3 SimplyRad OFFLINE
SimplyRad
  • 1,370 Thanks
  • 982 posts
Posted October 06, 2016 - 09:31 AM
Briggs I think it is a 243431. Can't see any tag with info.
#4 boyscout862 ONLINE
  • 13,692 Thanks
  • 9,476 posts
Posted October 06, 2016 - 10:14 AM
Clean the flywheel and magneto. Check the magneto leg gaps. Check that the spark plug wire hasn't been eaten by mice. Then give it a try. Good Luck, Rick
Edited by boyscout862, October 06, 2016 - 10:14 AM.
#5 SimplyRad OFFLINE
SimplyRad
  • 1,370 Thanks
  • 982 posts
Posted October 07, 2016 - 07:40 AM
What is the spacing for the leg gaps?
#6 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted October 07, 2016 - 08:24 AM
single peace of emery paper is fine for leg gap , just so they dont rub on the wheel when turned around
P S  make sure the stop wire is not shorting out anywhere too
Shane
Edited by holdenboy1960, October 07, 2016 - 08:25 AM.
  • SimplyRad said thank you
#7 hepaynoway OFFLINE
hepaynoway
  • 1 posts
Posted November 13, 2016 - 08:53 AM
My key switch was bad on my roof 60 little spark hard starting.changed it starts first time.
#8 SimplyRad OFFLINE
SimplyRad
  • 1,370 Thanks
  • 982 posts
Posted November 13, 2016 - 11:13 AM
I was out yesterday got to thinking it just may be the switch. Will just have to dig into the switch to check it out.
