Case 442 questions
3 replies to this topic
#1 thompson1600 OFFLINE
thompson1600
  • 2 Thanks
  • 39 posts
Posted May 27, 2011 - 08:01 PM
This 442 case does not have hydraulic lift for the deck. Does that mean it does not have hydraulics installed for the front and rear attachments? I believe this is a 1971 Case 442, serial number 9650321. Does the other photo with the spring pin, show the quick attach fast pin system? If so, would this tractor take the current front attachments, or have to use the older attachments?
Anything else that is important about the 442?
Can you add the hydraulics to the 442 so it has the hydraulic deck lift? or any other hydraulics it needs? Did the 1971's come with the control valve to maintain speed going downhill?
Thanks
#2 olcowhand ONLINE
  • 40,327 Thanks
  • 31,166 posts
Posted May 27, 2011 - 08:11 PM
The only thing I can tell you is it did not come with the hold-back valve. Most likely all the Case attachments will work with the quick attach. As to current Ingersol attachments, I've no idea. As to adding hydraulic lift, yes it could be done, but would cost many dollars for the components & may involve some engineering/welding if the chassis doesn't have the needed bracketry.
#3 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted May 27, 2011 - 09:32 PM
Thats the snap fast system so you can use the deck or snowblower off a 1971-1988 or so or a plow from 1971 on
#4 thompson1600 OFFLINE
thompson1600
  • 2 Thanks
  • 39 posts
Posted May 27, 2011 - 09:39 PM
Thank you. He wants $250 for it. Does not run, and no mower deck.
