Show off your leaf collecting and snow movers!
snow plows and blowers mowers and baggers
15 replies to this topic
#1 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted October 04, 2016 - 12:01 AM
Well, its officially AUTUMN-- so that means changing leaves, colder weather and SNOW right around the corner!
I figured Id start a thread for us to show off our leaf baggers and snow movers to the rest of the family!
Sadly, I dont have any leaf collectors --I just mow over mine with the Hustler Fastrack-- so I want to see your's!
Just tonight (finished after midnight) I found my 54" plow in a pile of weeds, finally fixed the frame so it was square for mounting, and got it hooked up to the 1812. I need to clean the carb on it before she is ready for use, and mount my weights on the 3-pt.
Ill also be keeping my eyes out for a snowplow for my little 73. I miss plowing with a narrow frame.
I want to see and hear about your setups, how they fair, and your favorite part about them! This will be my first year for the 1812!
  • Bolens 1000, Gtractor, limebuzz and 7 others have said thanks
#2 EricFromPa ONLINE
EricFromPa
  • 2,780 Thanks
  • 2,593 posts
Posted October 04, 2016 - 01:05 AM
Gimme your side panels lol.
I plan to be using the 582 with 42" plow for plowing but I might use the 70 and 42" plow a bit to.I have weights and chains and a plow for both.That's one Big plow 54" ?
I Might have to replace the clutch on the 582 before I can plow much with it.Couple chips out of it near the driver pins and it's getting thin.
I'll take some pics of them when the sun comes up.Still have to put my good seat on the 582 and swap out 1 front rim and get both cleaned up better but they should do the job.
Edited by EricFromPa, October 04, 2016 - 01:07 AM.
  • grnspot110, Alc and Dane in PA have said thanks
#3 propane1 ONLINE
propane1
  • 7,145 Thanks
  • 3,580 posts
Posted October 04, 2016 - 04:25 AM
This is some of the fleet. I don't have leaf equipment. I just use the mowers to chew them up.
Noel
  • Gtractor, grnspot110, Alc and 4 others have said thanks
#4 KennyP OFFLINE
  • 32,253 Thanks
  • 42,033 posts
Posted October 04, 2016 - 05:20 AM
Not much need for snow movers down here, but I just made a plow for Alice.
  • Gtractor, grnspot110, WrenchinOnIt and 2 others have said thanks
#5 David Brown OFFLINE
David Brown
  • 4,508 Thanks
  • 2,424 posts
Posted October 04, 2016 - 05:47 AM
For leaf collecting I have my 2003 315-8 and the Cyclone Rake.
Snow duty these days falls to the Massey GC1705 with 5 foot power angle blade.  After years of getting off the tractor to angle the blade, this was a welcomed thing.
I used to tag team the snow with a pair of Power Kings but I sold them to get the Massey.
  • grnspot110, tractorgarden, boyscout862 and 2 others have said thanks
#6 grnspot110 OFFLINE
grnspot110
  • 3,527 Thanks
  • 2,468 posts
Posted October 04, 2016 - 06:39 AM
Used to use a sweeper for leaf collection, worked good, but a lot of dumping!  Last year I found this on CL:  Garden Tractors 2015 001 (4).JPG  Garden Tractors 2015 001 (5).JPG
For snow, it was the JD 420 w/54 blade or 314 w/49 blower:  Pictures 2015 001.JPG  Probably won't even put the cab & blower on this season because I enjoy using the 1953-40S w/5' blade a lot more:  Tractor Shows 2015 003 (5).JPG
  • Gtractor, KennyP, boyscout862 and 2 others have said thanks
#7 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted October 04, 2016 - 07:35 AM
Used to use a sweeper for leaf collection, worked good, but a lot of dumping!  Last year I found this on CL:  attachicon.gifGarden Tractors 2015 001 (4).JPG
The picture of that trailer had me jealous before I read anything else.   :thumbs:
Looking good, guys!  Some good looking units cropping up.
Edited by Dane in PA, October 04, 2016 - 07:36 AM.
  • grnspot110 and propane1 have said thanks
#8 york0060 OFFLINE
york0060
  • 296 Thanks
  • 143 posts
Posted October 04, 2016 - 08:40 AM
I use my 318 with a Craftsman leaf vac. for leafs. I use a front blade on the 318 for snow, I also just got a little box blade to play in the snow with too.
  • Gtractor, grnspot110 and Dane in PA have said thanks
#9 Gtractor OFFLINE
Gtractor
    The Tractor Hoarder
  • 7,735 Thanks
  • 4,323 posts
Posted October 04, 2016 - 10:41 AM
I don't usually mess with leaves.  Live on top of a good size hill without much of a windbreak and the leaves tend to fly away on their own.  The leaves that get caught behind a car or whatever and don't blow away will vacate the next day when the wind changes direction.
I have this if needed.
Also have a Parker gas powered walk behind vacuum but its bag is a pain to dump.
As for snow,  I generally use the farm tractor,  a 1952 Ferguson.  Main problem with a garden tractor pushing snow is I have to clear an area in the pasture for the cows mineral supplement.  You hit a frozen cow patty with a garden tractor and you're gonna break something.  Maybe even your teeth on the steering wheel.  :hitting_self_roller:
The heat houser has me spoiled.
As a backup I have a Power King with a front blade and its weighted really good and does fantastic.  Just takes a lot longer.
Edited by Gtractor, October 04, 2016 - 10:44 AM.
  • grnspot110, WrenchinOnIt, Dane in PA and 1 other said thanks
#10 nitro OFFLINE
nitro
  • 170 Thanks
  • 113 posts
Posted October 04, 2016 - 11:18 AM
From last year.  I'm in the middle of assembling a power angle plow, and I rigged up a JD spreader for the back.  I think I'm trying some roller chain on the steer tires this year.
Edited by nitro, October 04, 2016 - 11:19 AM.
  • Gtractor and Dane in PA have said thanks
#11 propane1 ONLINE
propane1
  • 7,145 Thanks
  • 3,580 posts
Posted October 04, 2016 - 03:05 PM
Gtractor, nice ferguson you have. I have a 1951. I would like to have a heat houser for mine. We use a rear blade for snow.
Noel
  • Gtractor said thank you
#12 MGP59DB ONLINE
MGP59DB
  • 1,376 Thanks
  • 675 posts
Posted October 04, 2016 - 05:57 PM
I expect I will be using 'Rusty' for my little driveway again . He has wheel weights this year too.
This blade can be put onto the front of my SS12 - so I might try that out too.
Edited by MGP59DB, October 04, 2016 - 06:00 PM.
  • KennyP, Dane in PA and propane1 have said thanks
#13 shorty ONLINE
shorty
  • 4,348 Thanks
  • 4,515 posts
Posted October 04, 2016 - 07:15 PM
Our snow removal team. 1986 Gravely and Ariens blower.
Guess gravity got messed up in that storm.
Edited by KennyP, October 05, 2016 - 05:36 AM.
Fixed Gravity
  • Gtractor, KennyP and Dane in PA have said thanks
#14 Bolens 1000 OFFLINE
  • 13,631 Thanks
  • 17,575 posts
Posted October 04, 2016 - 07:19 PM
  • Gtractor, EricR and Dane in PA have said thanks
#15 Gtractor OFFLINE
Gtractor
    The Tractor Hoarder
  • 7,735 Thanks
  • 4,323 posts
Posted October 04, 2016 - 09:29 PM
Noel
You should go ahead and get one.  Dunn-O what they cost but its worth every penny.
Mine came with the tractor.  The windows were all bad so I fabricobbled in new ones.
Treated right, it'll last decades.   Amazing the difference they make.
  • propane1 said thank you
