RF 110
bearings
13 replies to this topic
#1 cubpuppy OFFLINE
cubpuppy
  • 1 Thanks
  • 8 posts
Posted October 03, 2016 - 12:47 PM
Does someone have the part numbers from JD for the front wheel bearings on a 1964 round fender?
Thanks
#2 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,141 posts
Posted October 03, 2016 - 07:30 PM
I don't have the part #'s or dimensions. Hapco has them.
http://hapcoparts.co...bearingkit.aspx
#3 cubpuppy OFFLINE
cubpuppy
  • 1 Thanks
  • 8 posts
Posted October 03, 2016 - 08:01 PM
Really don't want to spend 60.00.  I know if I can get a bearing number off them NAPA can get them.
#4 jabelman OFFLINE
jabelman
  • 2,249 Thanks
  • 1,609 posts
Posted October 03, 2016 - 08:13 PM
they should be able to match them up, if not try McMaster Carr. 60 bucks sounds ridiculous but it's john deere $$$
#5 hdg4400 OFFLINE
hdg4400
  • 295 Thanks
  • 358 posts
Posted October 03, 2016 - 08:50 PM
cubpuppy:
Found this site with front wheel bearings for tractors after a certain serial number.
http://www.greenpart...g-AM102605.html
Hope it helps.
Harlan
#6 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,141 posts
Posted October 03, 2016 - 09:48 PM
Hopefully Troy sees this thread, because I can't find the dimensions or standard part # for the tapered bearing or the race.
  • johndeereelfman and cubpuppy have said thanks
#7 Trav1s OFFLINE
Trav1s
  • 3,580 Thanks
  • 4,557 posts
Posted October 04, 2016 - 10:57 AM
Take the Deere part number to Napa and they should be able to x-reference them or
JD8188 - https://www.amazon.c...0/dp/B001OK4JNO
My googlefoo has not found out the inner bearing replacement yet.
  • cubpuppy said thank you
#8 secondtry OFFLINE
secondtry
  • 2,158 Thanks
  • 1,531 posts
Posted October 04, 2016 - 11:14 AM
cubpuppy:
Hope it helps.
Harlan
I don't get it. four pictures of a bearing it aint. Don
#9 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,141 posts
Posted October 04, 2016 - 01:46 PM
Front wheel bearing for later model 110's, not for your '64.
Edited by Cat385B, October 04, 2016 - 01:47 PM.
#10 cubpuppy OFFLINE
cubpuppy
  • 1 Thanks
  • 8 posts
Posted October 04, 2016 - 05:47 PM
.The Timkin numbers for the wheel bearings are:  inner  LM11900LA  $24.75 at Napa and LM11949VP is the outer bearing $7.83.  I took them off the tractor and found the numbers  These are for my 64 110.
  • Cat385B said thank you
#11 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted October 04, 2016 - 07:01 PM
The original part numbers are as follows:
outer bearings: JD 8188
inner bearings: JD8906
inner/outer races: JD 8226
Haven't checked with Deere lately to see if the numbers are still good or not, so you'll just have to try and see for yourself.
#12 KennyP ONLINE
  • 40,953 Thanks
  • 47,135 posts
Posted October 05, 2016 - 06:09 AM
Are those 3/4" or 1" bearings?
#13 hdg4400 OFFLINE
hdg4400
  • 295 Thanks
  • 358 posts
Posted October 05, 2016 - 08:49 AM
KennyP  et al:
This what JDParts says for the JD8188 bearing. So they are 3/4". They also say they at $4.96 each, and for what it's worth, my dealer in Plainview, MN has 3 on hand. If I needed them, they deliver free to their office here in Rochester.
English Metric       Specification
Weight:  0.18 LBS  0.08 Kg
Inside Dimension 0.750 IN
Width 0.655 IN
Radial Load LBs/N (Based on 3000 Hrs at 500 R.P.M.) 1,230.000 LBF
Thrust Load LBS/N (Based On 3000 Hrs at 500 R.P.M.) 635.000 LBF
Inner Corner Radius 0.050 IN Y-Factor 0.00 Finish   Note
Product Information Documents Bearings, Technical Information Taking a Risk with Non-OEM Bearings - Summary of Report Findings Maintenance Documents Bearing Maintenance Bearings, Rules for Lubricating
Crankshaft Main and Rod Bearings - Maintenance Guidelines
Harlan
Edited by hdg4400, October 05, 2016 - 08:53 AM.
#14 cubpuppy OFFLINE
cubpuppy
  • 1 Thanks
  • 8 posts
Posted October 06, 2016 - 06:14 AM
The inner bearings with the seal is the tough on to find.  Numbers I came up with is LM11949XL or LM11900LA-902A1
Also tagged with one or more of these keywords: bearings
