Kohler charging stator
5 replies to this topic
#1 dodge trucker OFFLINE
dodge trucker
  • 2,432 Thanks
  • 3,122 posts
Posted October 03, 2016 - 12:26 PM
I have my engine apart so I can't run it at the moment to check voltage under load
I know that there is a spec for resistance between the two AC terminals at the plug. Before I reassemble it just to possibly have to dismantle it again, does anyone know what checks can be made with it still apart? I am trying to avoid having to pull it apart twice.
#2 boyscout862 ONLINE
  • 12,843 Thanks
  • 9,169 posts
Posted October 03, 2016 - 12:29 PM
Download the manual from our Manuals Section and follow the troubleshooting section. Good Luck, Rick
#3 Bud W OFFLINE
Bud W
  • 325 Thanks
  • 302 posts
Posted October 03, 2016 - 02:56 PM
Ohm meter on Ohms, you should read a very low resistance (0.5-1±?ohms) measuring across the two leads, You should have infinite resistance (maximum) to ground from either of the two leads.
  • Bruce Dorsi, shorty and dodge trucker have said thanks
#4 dodge trucker OFFLINE
dodge trucker
  • 2,432 Thanks
  • 3,122 posts
Posted October 03, 2016 - 03:10 PM
Already have a paper copy but I didn't see that info in the book.
  • shorty said thank you
#5 boyscout862 ONLINE
  • 12,843 Thanks
  • 9,169 posts
Posted October 03, 2016 - 05:39 PM
Page 8.1 of this manual  http://gardentractor...service-manual/ tells how to troubleshoot the charging systems.
#6 dodge trucker OFFLINE
dodge trucker
  • 2,432 Thanks
  • 3,122 posts
Posted October 03, 2016 - 05:46 PM
thanks. The manuals that I have seen don't give that info....
