Coulters and disks question.
3 replies to this topic
#1 propane1 ONLINE
propane1
  • 8,721 Thanks
  • 4,126 posts
Posted October 03, 2016 - 07:57 AM
Does any body ever sharpin them. Was plowin yesterday and the coulter didn't want to cut the weeds and left over plants from the garden. It just seemed to keep the plow from diggin in right. So then I wondered about the disks if they would work better if sharp. I think they would get dull fairly fast once they get into the dirt. Just a weird question that I think I already know the answer to, but was wondering what other people do. It would wear out things quicker I would say, if it was sharpened a lot.
Your thoughts, please.
Noel.
#2 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted October 03, 2016 - 08:06 AM
Must be some tough weeds!  I've never heard of anyone sharpening their coulter.  I've been using the same plow since I was a kid and have never sharpened it.  It still feels rather sharp to me so I never though about it.  You would probably be better served by adding weight to the plow so it digs in better.  I've seen people do this since not many of these little tractors have down pressure.  When I go to a plow day and the soil is tough in spots, I'll just lean back and push down on the top link to get the plow to sink.  I think some weight would be your best bet or simply take the coulter off.
  • Alc and propane1 have said thanks
#3 propane1 ONLINE
propane1
  • 8,721 Thanks
  • 4,126 posts
Posted October 03, 2016 - 08:10 AM
I had thought about adding weight. You see that on the you tube videos.
Noel
#4 OldBuzzard ONLINE
OldBuzzard
  • 7,021 Thanks
  • 4,792 posts
Posted October 04, 2016 - 04:01 AM
I can't comment about coulter blades, but I do know that they used to sharpen disc blades back in the horse drawn days.  Here's a tool that they used to do that.
According to the gentleman that owned it, they would sharpen the blades as they were moving in the field.
For your problem though, I don't  think that sharpening the coulter would do much good.
What you need would be a notched coulter, and I don't know if Brinly even made those.  A notched coulter or disc blade is better suited to cutting trash.  The smooth blades are good in sod, and not-trashy ground.
Here are what the notched blades look like:
http://www.agrisuppl...-blade/p/41417/
ETA:  Adding weight to the plow should not be necessary.  When properly setup, a plow will pull itself down to the depth determined by the amount of 'tilt' that it has and will run at that depth without needing weight or a depth gauge wheel.
Edited by OldBuzzard, October 04, 2016 - 04:06 AM.
  • KennyP and propane1 have said thanks
