Briggs 25 hp hoist
4 replies to this topic
#1 jjln50 OFFLINE
jjln50
  • 11 Thanks
  • 18 posts
Posted October 01, 2016 - 06:05 PM
I am removing a 25 hp briggs from a john deere 115c. Is there a place to mount lifting brackets? I'm by myself and its too heavy to lift. Thanks
#2 boyscout862 ONLINE
  • 13,431 Thanks
  • 9,380 posts
Posted October 01, 2016 - 07:21 PM
If no other option is available, use a strap that cradles the entire engine. Make sure that you use additional straps to stabilize the lifting straps. Sometimes you can loosen existing bolts and bolt on lifting eyes. When I used to junk cars, I'd strip off any good looking eyes first. Couldn't find them last time I looked. Be carefull. Good Luck, Rick
  • jjln50 said thank you
#3 Mtypython ONLINE
Mtypython
  • 355 Thanks
  • 346 posts
Posted October 01, 2016 - 07:44 PM
take out ahead bolt go to hardware store buy eyebolts same size as head bolt
#4 EricFromPa OFFLINE
EricFromPa
  • 3,965 Thanks
  • 3,239 posts
Posted October 01, 2016 - 07:56 PM
The small 10mm bolts that hold the blower housing on are to short to lift from.
They Used to have 2 lifting points on them.1 was part of the Fuel Pump bracket and the other was on the opposite side of the Dipstick that bolted to one of the rear Blower housing bolts.But they did away with those after the Vanguard engines for some reason.Newer Inteks don't have lifting brackets.
There 81lbs Not to awfully bad to lift out if you bear hug them and use your legs to lift.I'm 144lbs wet and my back is a mess.Not supposed to lift over 30lbs but I do all the time and suffer for it 30 minutes to an hour later.
If you have a ratchet strap you could wrap it around the bottom of the engine and up over the flywheel cover and use the ratchet part to hook your hoist up to.That should be more than enough for 81lbs.
#5 jjln50 OFFLINE
jjln50
  • 11 Thanks
  • 18 posts
Posted October 02, 2016 - 09:43 AM
Thanks for all the suggestions. I ended up wrapping a ratchet strap around the engine twice and over the top to use as a sling for chain hoist worked great. Thanks all.
