Gutbrod 1010 in need of cutting belt.
4 replies to this topic
#1 bluesbob OFFLINE
bluesbob
  • 2 Thanks
  • 1 posts
Posted October 01, 2016 - 12:58 PM
Hello there, I have just joined your group and would very much appreciate some help on replacing a cutting belt on my recently purchased 40 odd year old 1010.
Firstly, what is the length of the belt ( I cannot seem to find a authentic replacement so if I knew the length, I can get any v belt).
Secondly, having tilted the miachine, there are two pulleys at the front.. does this mean there are 2 belts, one for each cutter?
If this is the case, I can only see one drive belt pulley!!
Can anyone please take pity on a numpty and give me some heads up?
Many thanks, Bob.
  • KennyP and Bolens800uk have said thanks
#2 boyscout862 OFFLINE
  • 12,864 Thanks
  • 9,175 posts
Posted October 01, 2016 - 02:43 PM
Welcome to GTT. There are a few of our members on your side of the pond that have those tractors. Do a search of our threads to find what has been posted. Check this page for manuals: http://gardentractor...ry/157-gutbrod/ . Please post some pics and be patient because those are rare tractors. Good Luck, Rick
  • TomLGT195 said thank you
#3 Cat385B OFFLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,004 posts
Posted October 01, 2016 - 04:20 PM
The two pulleys under the front are to help the belt make the 90° transition from the motor pulley (vertical) back to the mower deck drive pulley. (horizontal)
Sweet Mary Mother of All, after looking at more pics I think the motor is vertical shaft. Belt goes around a pulley between the motor and the frame, out the front around the mule drive pulleys, and then back around both spindles on the deck.
If you have no belt, I would use a small diameter rope, grab a helper, and place it around the motor pulley, over the mule drive, and back around the deck pulleys. Pull tight, mark where the rope overlaps, and then measure. Then buy a belt from a store with a generous return policy.
Edited by Cat385B, October 01, 2016 - 04:28 PM.
#4 KennyP OFFLINE
  • 38,419 Thanks
  • 45,945 posts
Posted October 01, 2016 - 05:41 PM
:wave: Welcome to the forum! Hope someone can help with the belt length!
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted October 05, 2016 - 03:34 PM
:welcometogttalk: :camera:
