Cub 782 engine swap
7 replies to this topic
#1 Ohiocartparts OFFLINE
Ohiocartparts
  • 1 Thanks
  • 7 posts
Posted October 01, 2016 - 09:43 AM
Hi to all new here I have Cub 782 with 300 hours the engine was run out oil over 30 years ago the previous owner pulled the engine and who knows what happened to it it has sat in a barn for 30+ years I have a Kohler ch20s available to go in this tractor just was wandering if it will work right direction , right hub
thanks in advanced
#2 IHCubGuy OFFLINE
IHCubGuy
  • 1,611 Thanks
  • 1,638 posts
Posted October 01, 2016 - 10:16 AM
The spec number on the CH20 will determine how it was setup.  With a picture we can give a little beter idea of what the engine might take to get it into the Cub.  I'm not real familiar with the exact size of a command so I can't say for sure but it might require the removal of the side tins to ft it in.  As far as hooking it up to the tractor itself, anything is possible with enough fabrication.  Just depends how wild you want to get with it.
Post a picture or two of the CH20 from both the crankshaft side and the flywheel side so we can get a look at it.  Also the spec number or a picture of the tag.  As far as rotation, Cub Cadets ran the transmission from the flywheel side and the pto from the crankshaft side of the engine.
#3 boyscout862 OFFLINE
  • 13,550 Thanks
  • 9,427 posts
Posted October 01, 2016 - 12:38 PM
Welcome to GTT. Check our Manuals Section for info too. Good Luck, Rick
#4 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,174 Thanks
  • 2,254 posts
Posted October 01, 2016 - 03:57 PM
Evidently it's been done before.  i found this when searching for info on swapping a magnum into one of my tractors.
Hope it helps.    Rick
#5 Ohiocartparts OFFLINE
Ohiocartparts
  • 1 Thanks
  • 7 posts
Posted October 01, 2016 - 07:51 PM
Thanks for the response the engine tag says model CH20S, Spec no. 64510, serial no. 2225911367 as far as fabrication I own a golf cart sales and service shop so I have welders, torches, plsma cutters, benders so fab is not a problem I will post some pictures as soon as i figure out how to get them up here. Again the motor came off of a 1993 grasshopper 720k
#6 KennyP ONLINE
  • 40,886 Thanks
  • 47,094 posts
Posted October 02, 2016 - 06:33 AM
:wave: Welcome to the forum! Pic help can be found in the link in my signature. Hope to see some pics soon.
#7 KennyP ONLINE
  • 40,886 Thanks
  • 47,094 posts
Posted October 02, 2016 - 06:36 AM
Hope it helps.    Rick
I saved a copy of that pic. I'll make it a PDF and upload to the Cub Manuals section so it's not lost.
  • EricR said thank you
#8 Ohiocartparts OFFLINE
Ohiocartparts
  • 1 Thanks
  • 7 posts
Posted October 02, 2016 - 08:51 AM
I was not able to get the actual pictures to upload here; however he are viewable links that you can view.
Edited by Ohiocartparts, October 02, 2016 - 08:54 AM.
