found in my Bolens frame
7 replies to this topic
#1 thom OFFLINE
thom
  • 339 Thanks
  • 244 posts
Posted September 30, 2016 - 11:33 PM
Two pieces of flat steel slid out of my Bolens frame after I disassembled it.
I suppose they were put in to keep bolts from "squeezing" the frame tubes. I Don't know where they were ? Anybody know how far they need to slide back in upon reassembly? Thanks
  • Traill95, boyscout862, Sawdust and 1 other said thanks
#2 glgrumpy OFFLINE
  • 8,601 Thanks
  • 7,906 posts
Posted September 30, 2016 - 11:57 PM
I got up to four of those from my G14 frame. I was thinking the bolt squeezing thing also. It does show them on a parts page, but not where inserted or how. I was trying to put mine in, but tightening the trans clamps and front bolster bolts did NOT seem to hold that metal in any way, so just pulled mine out and not used then. Didn't want them rattling in the tubes once it gets running and used. Not sure if that is Wrong or what, but I'm satisfied w/out them. I did not see any mention in the repair manual about them either, unless I missed it?
  • boyscout862, Sawdust and holdenboy1960 have said thanks
#3 thom OFFLINE
thom
  • 339 Thanks
  • 244 posts
Posted October 01, 2016 - 01:07 AM
Actually , mine had four also, two in each tube. I believe that one of mine remained in place and they go in the front of the tubes for the bolts that go thru the tubes and into the cast front crossmember. That would be the part with the hole for the pin that the front axle pivots on. That pin is, so far the only part that has given me any grief during disassembly. I want it out  to seperate it from the axle for cleaning and painting. I might drill it and replace it with a new one. Caution will be necessary to keep from breaking the cast part.
Edited by thom, October 01, 2016 - 05:45 AM.
  • MH81, boyscout862 and holdenboy1960 have said thanks
#4 Bolens 1000 OFFLINE
  • 14,978 Thanks
  • 18,135 posts
Posted October 01, 2016 - 08:34 AM
Those are  for frame reinforcement
  • MH81, WrenchinOnIt, Sawdust and 1 other said thanks
#5 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted October 01, 2016 - 09:28 AM
Actually , mine had four also, two in each tube. I believe ... they go in the front of the tubes for the bolts that go thru the tubes and into the cast front crossmember.
Yes, they go into the front of the tubes to reinforce the tubes where the engine bolts go through the tubes.
They are inserted vertically and straddle the bolts.
There was a Bolens Service Bulletin issued about this.
  • MH81 and holdenboy1960 have said thanks
#6 Xrperry ONLINE
Xrperry
  • 1,022 Thanks
  • 762 posts
Posted October 01, 2016 - 10:25 AM
As tough as bolens are why didn't they use solid stock and plug weld them in place?
#7 Bolens 1000 OFFLINE
  • 14,978 Thanks
  • 18,135 posts
Posted October 01, 2016 - 12:47 PM
Really was no need to as the frame was never really compromised no matter what work you did, from my understanding the reason they came out with these kits and later came with these in them is alot of people were getting a little too carried away ramming snow piles or dirt piles with the front blade which would loosen the bolts and crush the tubes.
  • holdenboy1960 and Xrperry have said thanks
#8 Xrperry ONLINE
Xrperry
  • 1,022 Thanks
  • 762 posts
Posted October 01, 2016 - 12:54 PM
makes sense, i kinda beat my g9 on snow piles once or twice
